Fireplace couldn’t of happened without the GC.
   / Fireplace couldn’t of happened without the GC.
That's a beautiful piece of work! Any reason why your rear tires are on backwards?
Actually I went and had them filled (beet juice) and when I was going to remount them I had a little thought. The V pattern on a tire is there to clean-out the mud as you move forward, but in hard pack, rock, or loose sand/dirt, you get better traction running tires backwards (its from my buggy/offroad days (consensus proven)). Also if I do get into a muddy situation (only once so far)....I usually am smart enough to back out before it's too late....my tires work better in the mud going backwards...which means my stupid self driving into the mud can't get as far and actually have better traction to reverse and find a new path....
I'm a bit of an oddball who doesn't conform to much.....
   / Fireplace couldn’t of happened without the GC. #12
These tractors are the swiss army knife of tractors. I have done way too many projects to list....actually I did post it a while back. One my best projects was to move and landscape 36-eightteen yard dump truck loads of sand, dirt, gravel, and loam all with this tractor loader and a landpride box blade.
   / Fireplace couldn’t of happened without the GC. #13
Nice work, these little tractors just don't say no..
I would love to get to work a boxblade that much.....I just use mine for some trail grooming....so much fun with hydraulic top and tilt!
   / Fireplace couldn’t of happened without the GC. #15
Nice project, well done!
   / Fireplace couldn’t of happened without the GC. #16
Re: Fireplace couldn稚 of happened without the GC.
Looks great, and I agree-- these little tractors are very handy! Wish I had bought mine years before I (finally) did...
Oh, BTW-- take a peek at your motor mounts....
   / Fireplace couldn’t of happened without the GC. #17
GC1710,
I noticed the bolts, too. I like the hooks on both sides. I have only one mounted in the middle and sometimes I'd like to share the load to both sides. You mentioned shear load is bad for the bolts but aren't bolts pretty strong this way? It seemed to me that rotating or torquing the bolts forward would be the weak issue. What do you use for a backing plate on the bolts to handle the "bend over" force. It looks like the hooks swivel so you must have some sort of a stop on the bolt as you screw it down into the bucket.
   / Fireplace couldn’t of happened without the GC. #18
Gc1710,
A very interesting project. Nicely designed. But the pictures seem to show this is built very close to trees and shrubs and overhanging limbs. Isn't this a concern for heat exposure to those branches, limbs, and brush?
2015 KENWORTH T270 SERVICE TRUCK (A51406)
2015 KENWORTH T270...
2011 JOHN DEERE 670G MOTORGRADER (A51406)
2011 JOHN DEERE...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
1837 (A51248)
1837 (A51248)
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
