Firepit Question
   / Firepit Question #11
Looks about the right size to drop a tractor rim into. Try your local tractor dealership or ag tire dealer and see if you can get a rusted out rim to drop into the middle.
Aaron Z
   / Firepit Question #12
Would putting a drum slightly smaller than the inner hole in the middle, then pouring a mix of fire clay, in between the drum and stones work. And as a after thought, what about mixing in say some fibre glass fibres in with the clay. I`ve no idea if it would work, I`ve not seen a firepit.....
   / Firepit Question #13
Build bigger fires to keep their feet away. :D
I think any long term solutions are going the involve taking it all apart and starting over. If you are committed to mortar, take it apart and do it right. If you have access to more rocks I would try to find some larger flat rocks. Then rebuild the pit with loose rocks, no mortar and top it with flat rocks. Make it so the flat rocks are solid and won't fall off. Let's us know when the next wienie roast is.
Doug in SW IA
   / Firepit Question #14
Consider using an angle grinder with a concrete blade, hammer and chisel to shape the rocks for a dry fit. Done properly it will last and look much better than grouted rock.
The rocks may cut much easier than you think. If the rocks are larger add a hammer drill and feathers and wedges for really nice cracks.
   / Firepit Question #15
I like it as it is. Is it so awful just putting the rocks back?
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
Bef-Co Finish Mower - INOPERABLE/PARTS ONLY (A52128)
Bef-Co Finish...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
