Fire season is here-time for serious mowing with the hog
   / Fire season is here-time for serious mowing with the hog #11
Apply Fluid Film, or similar, when you reassemble and your problems will be reduced significantly
I've been using a bit of motor oil when I reassemble and both the nuts and bolts come off with no problem. :)
Terry
Do you have a big pneumatic impact wrench. That is what I use. Makes blade removal pretty easy.
When I was a kid we used to take the blades to our local blacksmith for truing up the cutting edges. The new blade won't take the heat and beat method.
Like the removable plate.
Sent from my iPad using TractorByNet
Have an impact wrench. Still like the removable plate--don't have to work under the mower at all using that method. Safety first, last and always :thumbsup:
Same here. My grandfather was a blacksmith. As a lad I helped (actually mostly watched) him in his shop working on all kinds of implements.
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2015 KENWORTH T660 SLEEPER TRUCK (A58214)
2015 KENWORTH T660...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 LEDWELL 48FT DOVETAIL TRAILER (A58214)
2012 LEDWELL 48FT...
