Fire Safes
   / Fire Safes #1
Bird
Rest in Peace
Corinth, Texas
I'm considering buying a very small fire safe (or perhaps more correctly, a fire resistant safe). I'm trying to decide between that and a safe deposit box, but it's an awfully long drive to the bank I use that has safe deposit boxes. My concern is not with security and valuables; i.e., burglary, theft, etc. but just something to keep items such as insurance policies, vehicle titles, our wills, credit card and bank account numbers, etc. to have in the event of fire and/or tornado. And of course, I want something light enough in weight to bring up the steps into the house by myself with my two wheeled dolly. And I'd like to not spend a lot of money (wouldn't we all?). Here is one that Sam's Club has just for a starter. Does anyone have a better recommendation or any advice?
   / Fire Safes #2
If that is the brand you want then I would go to the next biggest size. The 1 cf model you mentioned is pretty small.
I have an older model Gardall safe with about the same dimensions as the Fire Fyter larger size. It weighs about 350lbs, cost about $600 ten years ago and is rated for 2 hours at 1700F. Its 2+ cubic feet capacity seems small but all my documents and several other valuable items fit inside with no problem.
I also have a smaller safe (a little over 1 cf) that I used in my store for coin storage that has the same double key locking mechanism which is real handy if the electronic lock batteries go dead or you forget the combination /forums/images/graemlins/blush.gif.
   / Fire Safes #3
Bird,
Target (among others) sells one made by Brinks. I have one, but would not recommend it. It is so touchy on the dial, that I have to try it 3-4 times before I can open it. I HAVE to have the book with me when I try it. It also requires the key AND the combination. That may be good, but I really think there's a better one out there for me.
   / Fire Safes #4
We use a digital safe that is lagged to the floor. The keypad is much easier to use than a dial. unfortunately I don't believe that it is fire rated.
   / Fire Safes #5
Bird,
The safe you are looking at meets UL Class 350 C standard meaning it can withstand 1700 F for one hour. BUT the temperature inside of the safe can go as high as 350 F. Fine for paper, but not credit cards, computer data, photos, etc. or anything plastic that could be destroyed should a fire occur. For magnetic tape and photos a UL Class 150 safe should be used, for floppy disks and other computer data a UL Class 125 safe should be used. Safes come in varies hour ratings from 30 minutes to 4 hours. The lower the class rating 125 vs. 350 and the longer the safe can withstand a fire, the more $$$ you will spend.
When I evaluate computer sites or business owners most make the mistake of putting computer data in a safe that if they had a fire would have not prevent the loss of data, are Class 350 safes. Most safes that are more then say 10-15 years old are paper safes, not computer data safes. They maybe big and heavy and cost a lot $$$ but will not protect the computer data in a fire. Backing up computer data everyday and storing the data in a safe not rated for computer data is not a wise thing to do. The other thing I see all the time is the safe is open. Of course they all say I was just in it, and we would make sure we close the safe door during a fire. Sure while you are saving your butt from a fire you will remember to close the safe door. /forums/images/graemlins/blush.gif
OK insurance loss prevention hat is off now.. /forums/images/graemlins/grin.gif
Bird the safe looks OK, a little small, use for paper only. I keep our important data in a bank safety deposit box. I feel that is the best possible protection for information I do not want to loose.
   / Fire Safes #6
Bird,
I'd suggest you make a 1 cu ft box and trying to fit everything you want to put in the safe into the box. You might be suprised at how little fits in that.
We went to a used office equipment store and bought a fire proof 4 drawer lateral file which I think was $400 delivered and placed where we wanted it. It hasn't moved since. It's very heavy. It's not good for plastic, but I take my backups to work and keep them in a drawer there. Probably more than you want, but I'm just tossing out ideas. The point is, don't rule out the used market. Try your local used office furniture places. They will usually deliver and place the safe for you.
You might also want to find out where the coolest place in your house will be in the event of a fire. I don't know where that is, but it could make a big difference on the likelyhood of your papers surviving a fire in a fire safe.
Cliff
   / Fire Safes #8
Bird,
Used market is a good idea. If the safe meets UL requirements for fire it will have a UL label on the safe with its rating. The label will be either on the inside on the door or door frame usually on the bottom, or on the outside at the bottom of the door. If the safe was constructed before 1972 it will have a label with A, B, C A= 3 hours, B= 2 hours and C = 1 hour and will be only a paper safe. If it is newer it will say Class 350, Class 150 and Class 125 with the hour rating.
Here is a link with all the technical stuff on Fire safes.
web page
Oh do not store valuables, $$$, gold, etc. in a fire safe if you are trying to protect it from burglary. Fire safes do not provide resistance to burglars. If a safe has a round door, it is a burglary rated safe and if it has a square or rectangle door it is a fire safe. To my knowledge they do not make a fire and burglary safe as one unit.
   / Fire Safes #9
I've taken my I.T. data assurance skills home with me! Now that my family has switched to an entirely digital format for video and pictures, I take data backup seriously. I burn everything to CD/DVD. I view it to assure it is good, I make 3 copies. I store 1 in the house, 1 in the shed in a sealed tupperware container and 1 at grandmas. Data is finickey and I would not trust it in any fire safe. Paper at 350 will start to char but will be readable usable.
As for a firesafe for documents with no security needed.... Buid it yourself. All you need is gypsum board (that's all they put in the firesafes!). The gypsum gives off water when heated thus providing a cooling effect for as long as the water remains. That is why they are rated for different times and temps. I.E. how thick is the gypsum board and how many sheets are used. I would start with a BIG cooler (old metal one would be best). Then Build a several layer thick gypsum box with a graduatingly larger sized lid so it fits like a stopper on the top. Store it in a corner of the basement where there is the least flamable material.I might even wrap the cooler in double bubble aliminized foil insulation wrap (like AC vents use). That would reflect radient heat a long time all on its own. With the gypum around it, it could be made good for hours.
I considered building a gun safe with fire capability, but with the little ones around, who has the time to do that? But a simple fire safe could be done in a day for cheap!
   / Fire Safes #10
Tom that statement may be a bit broad to cover all safes made. We have an Elsafe used to secure our handguns. The company is famous for manufacturing safes for the hotel industry, fact is we first used one when we stayed in a nice hotel in Florida and fell in love with the safe. The door is rectangular and I can assure you that it is not fire rated.
About Elsafe International AS
With the invention of the world's first electronic in-room safe in 1979, Elsafe revolutionized hotel guestroom security. For over 23 years since, Elsafe has maintained this position of leadership, continuously introducing new products that combine unparalleled strength and durability with technological superiority. Recently, the company became the first safe manufacturer to pass the stringent UL break-in test with the popular Infinity™ Collection. The company also was the first to successfully incorporate biometric access technology into an in-room safe. This Biometric safe was awarded the "Editor's Choice" Award for best new product at the 2001 International Hotel/Motel & Restaurant Show in New York. Currently, Elsafe products are installed in nearly 1 million hotel rooms and cruise ship cabins around the globe. Used by virtually every major hotel chain in over 130 countries, Elsafe is the most trusted name in guestroom security. Elsafe is part of the VingCard group. VingCard belongs to the ASSA ABLOY group, a public Swedish company traded on the Stockholm Stock Exchange. The group's expansive international network consists of 11 subsidiaries and 75 distributors. Currently, the group has around 30,000 employees and annual sales of approx. USD 3 billion. For more information, please visit www.elsafe.com or www.assaabloy.com.
TC-40D SS web pictures click here
2008 Chevrolet Impala 50th Anniversary Sedan (A51694)
2008 Chevrolet...
2024 John Deere 6110M (A50120)
2024 John Deere...
2016 FREIGHTLINER CASCADIA DAY CAB (A52141)
2016 FREIGHTLINER...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
