Fire Extinguisher Mounting
/ Fire Extinguisher Mounting #1
woodyacres
SE Michigan
Kioti DK35SE
How many of you have extinguishers mounted on your tractor. I just mounted one today.
/ Fire Extinguisher Mounting #2
I put a 5#er behind the right step this fall and I already got to use it ! I was working with my tree guys and they brought their Toro Dingo to haul brush. a bunch of dry leaves got packed under it and caught fire. They were trying to stomp it out but the fire was gaining on them and was pretty close to setting the rubber tracks and hoses on fire. They were mighty glad I was there to snuff it out . They have since add extinguishers to their chippers and the Dingo !
/ Fire Extinguisher Mounting #3
I have one also. Cheapest Insurance I can get..
/ Fire Extinguisher Mounting #4
I've been thinking about where a good spot would be to mount an extinguisher on the tractor.
When I first got my shop that was one of the very first things I got for it, mounted it beside the door since I figured I would naturally want to go there in the event of a fire.
/ Fire Extinguisher Mounting #5
It's on my list for Spring...Thanks for the reminder.
Don
/ Fire Extinguisher Mounting #6
I mounted mine on the rops upright using some large zip ties to mount the oem extinguisher bracket.
worked great.. use it on both my rops equipped tractors.
soundguy
/ Fire Extinguisher Mounting #8
If anyone has mounted one in a cab tractor, I'd love to get some suggestions.
Pete
/ Fire Extinguisher Mounting #9
Pete
Inside the cab.cut a half section of 6 inch steel pipe welded it in ,works good
ALAN
/ Fire Extinguisher Mounting #11
Great ideas everyone. Now about maintenance:
Vibrating equipment can cause the powder to pack down. Every six months or so, take the extinguisher off the tractor, turn over and rap the bottom hard with a rubber hammer. I used to say,' turn it upside down and hit it on a tire before use', but in the excitement that seems to get over looked.
If it is outside, put a soft, easily remembered to be removed, plug in the nozzle or cover with something. Wasps, bees such can build nests in the larger hose nozzles leaving you with the potential of two problems. Smaller nozzles are prone to mud-daubers, carpenter bees. This happens in barns as well.
I have a couple of ways I prepare: I have a 5 lb ABC on the ROPS and a 2.5 gallon H2O extinguisher on the brush hog mower.
Be safe.
/ Fire Extinguisher Mounting #13
I had mine on rops tree branch snaggeed latch and tore off. Next time will turn guage to inside as branch tore gauge lose
/ Fire Extinguisher Mounting #14
Rops with two hose clamps on my old 750. thanks for the reminder, gotta get one on the new machine.
/ Fire Extinguisher Mounting #15
@ALAN: tnx for pix, I've got a JD 4520 cab which doesn't have a nice spot like you found. If I get a solution I'll post.
I have a brother in Brownfield, ME. Nice country up there.
@Cidertom: Good advice. I also give my dry powered extinguishers at home a shake (no hammers, just shake them) every new years day so they don't get compacted.
@everyone: So far there are two downsides to cab tractors: no room/bad room for toolboxes and fire extinguishers. I'll focus on it this spring...
Pete
/ Fire Extinguisher Mounting #16
A quick question for Slacker; is that a plastic side chair you're using for a seat?
Now back to our regularly scheduled thread.
/ Fire Extinguisher Mounting #17
Yes, it's a school chair with the legs cut off. Not very soft. I used an old square life jacket as a pad.
/ Fire Extinguisher Mounting #19
dont forget to do a monthly inspection on those extinguishers to check for pressure, hose cleanliness and rust on any pressure part. I would do the upside down shake, rattle and roll at least every month also. At the office we send them in for service every 12 months (we have the CO2 cartridge type ) and the service tech takes all the powder out and replaces it, checks the co2 cartridge and then recertifies it with a new sticker. I dont think the powder would be good for that long on a tractor without settling and compacting. I dont have one on my tractor, but I think I will get one for it. Maybe a nice CO2 type. NO powder settling problem with that. Having seen many powder extinguishers used to try to put out a paper fire, I would not trust them to put out burning leaves either. I watched a guy use up a 20lb. ABC powder type on some burning burlap bags and the fire never was put out. The bags were on some grating so it just kept feeding the oxygen to it. A good CO2 would have snuffed it completely.
/ Fire Extinguisher Mounting #20
I was able to find a handy spot just inside the left side cab door. I screwed the mounting bracket to hold it firmly in place. The location also allows me to access the extinguiser if I am standing outside the tractor. I have had it there for over a year now and it hasn't gotten in my way yet or blocked my vision.
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
2019 Kubota M5-091 (A64911)
2019 Kubota M5-091...
2025 Sickle Bar Mower Mini Excavator Attachment (A66734)
2025 Sickle Bar...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2015 CHEVROLET SILVERADO 2500HD (A67714)
2015 CHEVROLET...
CAT 416B Front Loader Bucket (A68134)
CAT 416B Front...
