Fire Extinguisher (I think I was lucky)
   / Fire Extinguisher (I think I was lucky) #1
BlueBit
Ponder Texas
2017 NH Workmaster 33. Previous tractor: NH TC24D
I owned a NH TC24D for 13 years until I recently traded it in for a 2017 NH Workmaster 33. The Workmaster has a regen every 5 hours or so. I got concerned with the increased exhaust temps, especially when bush hogging way back in the back of my property where I could expect no help and the grass and weeds were always 18 or taller, much taller. So I decided to add a fire extinguisher to the new tractor. Nothing new here, but maybe I will save someone some research time. The pics show an Amerex 2.5 lb abc with the metal mount. I installed it on my 2 x 3 ROPS with two 3.5 stainless hose clamps.
   / Fire Extinguisher (I think I was lucky) #2
ABC will do good for something on the tractor but won’t do much for a grass fire. Carry a shovel or other digging/scraping tool and check out the Indian Backpack Pumps. A little water will go a long way.
   / Fire Extinguisher (I think I was lucky) #3
I need to look to see where I could mount a fire extinguisher in my cab. I do have a first aid kit, but no extinguisher...yet.
   / Fire Extinguisher (I think I was lucky) #4
I remember when Ipurchased my firs bran new 1999 Kubota L series tractor and thought it was invincible.
It has the HST tranny which was new to me but didn't stop me from getting right to work.
First thing was cleaning a large brush area and get it ready for a burn pile.
I lit the fire, had two people nearby with 2" fire hoses charged "in case" of any get away even though the area had
a large safe area.
As I was feeding the fire with the grappler reaching far into the fire and dropping my loads.
One time I drove in a little deep where the front tire were in the fire - and the tractor stalled.
There I am sitting on a stalled open air tractor and the load I just dropped ignighted and I'm stalled on the fire
with flames licking the entire front of my trartor, what do I do? Do I jump because I can still make a clean getaway
or start the tractor and hope it starts?
Well I hit the key it started and I flew out of there with smoking tires and a few melted plastic bits on the front.
I'm guessing I had seconds either way.
Now you know why I didn't go to college.
   / Fire Extinguisher (I think I was lucky) #5
Looks good. I have been considering adding one to a few pieces of equipment. If for no other reason to just have them around and know where they are at.
   / Fire Extinguisher (I think I was lucky) #6
Just remember. You need to be able to direct the extinguisher at the source of the fire. THAT, may not be achieavable given the design of much modern equipment.
A friend set fire to a tractor while doing a welding repair. It had a plastic fuel line with a top mounted gravity fed tank. A really, really bad situation!
   / Fire Extinguisher (I think I was lucky) #7
There are a lot of welding fire stories out there. Have several FE in the garage. I was wondering if the 2.5 Lb is big enough, especially for a fuel fire.
   / Fire Extinguisher (I think I was lucky) #8
Having fire fighting equipment at hand is one thing, but a having a spotter is just as important. A welder, burned down a whole (newly rennovated) ice cream factory near here some years back!
I have seen too many welders that think it's funny when people get excited about sparks and a "little" fire.
But back to the topic. To me, it's more important to consider before hand, where a fire is likely to break out and how to get at it, than where to mount your extinguisher.
   / Fire Extinguisher (I think I was lucky) #9
a large safe area.
I think that sounds like perfect college material...... :)
   / Fire Extinguisher (I think I was lucky) #10
You all give some thought to the handles on those extinguishers. Tree limbs and loose clothing can be a issue. Tree limbs also can pull that safety pin right out. Guess it depends on your mowing conditions, but it’s something to keep in mind.
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2008 GMC C7500 Altec LRV55 55ft Forestry Chipper Bucket Truck (A50323)
2008 GMC C7500...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
APPROX 21 SIDEWINDERS (A52472)
APPROX 21...
