Fire Extinguisher holder
/ Fire Extinguisher holder #1
Casco1
New England
Kubota L series
It's nothing fancy but it does the job, mainly I wanted to try out the camera.
Two 3" PVC couplings at the bottom I glued a 1/2" piece of 3" pipe to keep the extuinguisher from falling through also it doesn't hold water or dirt. Next job is to attach a lenght 10" to 14" of 4" PVC fencepost with a cap to hold tools. As you've probably guessed I can"t weld.
/ Fire Extinguisher holder #3
Good idea, looks nice. I just mounted the extinguisher bracket on the Case ROPS w/ HD tye wraps, it sits on the base of the ROPS. /forums/images/graemlins/grin.gif
/ Fire Extinguisher holder #4
Dont need to weld if it works /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Mine is just a piece of flat bar bolted to my triangle holder and the the bracket mounts to that. It was to close to the base of the rops to just bolt it on. /forums/images/graemlins/frown.gif
/ Fire Extinguisher holder #5
Guy,
Great idea... But there may be a problem.....
Many years ago I had the Coast Guard do a safety inspection on my boat. The only problem they found was the way the fire extinguishers were mounted. They claimed if they were mounted vertically they would tend to "pack" all of the solids on the bottom of the tank due to the constant pounding and possibly not discharge properly. They recommended mounting the extinguisher horizontally. Since the boat (and the tractor) will tend to keep the solids less packed due to the rolling effect of the boat. Just a thought... hope this is of some help.
I like the idea of mounting an extinguisher, I think I will be doing the same.
Gary
/ Fire Extinguisher holder #6
Very valid point Gary. I've got into the habit of tilting my extinguishers back and forth a couple of times until I am sure I can feel the contents moving from end to end. You can feel the weight transfer. However a horizontal mount would automatically do that for you.
Gary, In all my years of working construction I've never seen an extinguisher mounted horizontally. In a way his theory may make sense but I suspect it may have been a situation where your boat checked out and the inspector just had to find something wrong to comment on. For years before getting a final inspection done by a building inspector I would deliberately leave one or two obvious items undone to give the inspector something to find wrong. It made him happy finding a mistake and usually stopped him from tearing the job apart until he did find something wrong.
/ Fire Extinguisher holder #8
Guy,
The inspector was one that was invited to our marina in Florida. I knew him. Don't think he was looking for a problem.
I know what you mean about finding a problem... when I was involved in racing we used to call it "throwing them a bone" .... Give them a problem to find and they will leave you alone. Or stop looking for the real problem!!!!! /forums/images/graemlins/wink.gif
I don't think this was the case with this Coast Guard inspector, but he might have overstated the problem. Never the less, it did make sense. Since then I have always mounted them horizontally. Just thought I would pass it along. /forums/images/graemlins/cool.gif
But I will be following your lead and mounting a fire extinguisher as soon as the weather warms up a bit Thanks for the idea!!!!!
Gary
/ Fire Extinguisher holder #9
Dave,
I used to check the ones on my boat and did find they were never "packed" once I mounted them horizontally. I am a believer .... I have to believe the same will hold true for an extinguisher mounted on a tractor. Now I just need to mount one!!!!! /forums/images/graemlins/confused.gif
Gary
/ Fire Extinguisher holder #10
Interesting thought about mounting horoz. Somehow I suspect I get the tractor bouncing up and down enough to make a Martini, never mind keeping extinguisher powder agitated /forums/images/graemlins/grin.gif I have fired off plenty of units at the end of a job when they hung on the wall for a year, they discharged /forums/images/graemlins/smirk.gif
/ Fire Extinguisher holder #11
</font><font color="blue" class="small">( but I suspect it may have been a situation where your boat checked out and the inspector just had to find something wrong to comment on. )</font>
Ditto.
All of our door mount fire extinguishers on our mack trucks come with verticle mounts from the factory.. and they pass DOT inspection. Our shop yard also passes routine insurance and OSHA inspections every couple years. All of our extinguishers are verticle mount.
I see the same in the restaurants and other comercial buildings.. like kmart / wallmart, etc.. verticle mount Fire extinguishers.. etc.
If there was a really huge problem with verticle mounting.. seems that they wouldn't pass inspections.
Might even be a throw back from 'old days'.. like about storing batteries on concrete.. etc.
Soundguy
/ Fire Extinguisher holder #12
Its just like tapping a can of skoal the more you tap the can the more it packs. Now the tractor does have more side to side but settling of the powder is gonna happen. But at least when I start the nex big brush fire in so cal I can at least say I had an extinguisher /forums/images/graemlins/grin.gif
/ Fire Extinguisher holder #13
Its just like tapping a can of skoal the more you tap the can the more it packs. Now the tractor does have more side to side but settling of the powder is gonna happen. I just have to swap it out with my jeep from time to time. But it all comes down to personal opinion.
/ Fire Extinguisher holder #14
My mount is the same as MrJoe, simply tye wrapped to the back of the ROPS. I guess if packing is a real issue, I would rather have to shake the extinguisher alittle as opposed to watching my tractor burn for lack of one. All the farm tractors I have been in had them mounted in the upright position. They sure beat a gallon milk jug of water (personal experience) for putting out a fire. /forums/images/graemlins/grin.gif
/ Fire Extinguisher holder #15
As the former maintenace tech for all the extinguishers on our volunteer fire dept. I can say without doubt that extinguishers that have ridden on trucks for a long time tend to discharge less powder than units that sit stationary. We resolved this problem by taking all extinguishers and turning them upside down and tapping them a few times with a rubber hammer every 3 months. this greatly improved the amount of powder discharged when used. /forums/images/graemlins/smile.gif
JMR Tree Boom Mini Skid Steer Attachment (A64553)
JMR Tree Boom Mini...
2012 JOHN DEERE 210G LC EXCAVATOR (A65053)
2012 JOHN DEERE...
2022 BOBCAT T76 PLATINUM R-SERIES SKID STEER (A65053)
2022 BOBCAT T76...
2016 Freightliner M2 106 Ambulance (A64556)
2016 Freightliner...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2022 YANMAR VIO35-6A EXCAVATOR (A63276)
2022 YANMAR...
