Fire Extinguisher Checks
/ Fire Extinguisher Checks #1
zzvyb6
Super Member
michigan
jd 1070
I did a walk around my barn and shop today and noticed that just about all my fire extinguisher's nozzles were all plugged up by insects. Not sure what they are, but they have always jambed up the ground hole in my electrical sockets or even air line tool fiittings. They build a mud nest in this sized hole, inject a larvae and seal it up completely with mud. Bad idea for a fire extinguisher. I unscrewed the nozzles and used a small drill to ream out the mud etc. I hope you never need one, but in case you have them hanging around outside or in sheds or buildings, check the nozzles. I think I've seen plastic or rubber plugs to solve this problem at TSC or Lowes/Menards/Home Depot, etc/
/ Fire Extinguisher Checks #2
Another good thing to do is shake them extinguishers every so often. If they are the powder kind it can all cake up on the bottom after a few years. I take and rotate my extinguishers every few months from hanging normally to laying on their side. And I shake the goober out of them. Having the nozzle plugged would certainly affect them. I haven't found any with bugs or anything else. Maybe use the foam ear plugs?
/ Fire Extinguisher Checks #3
It's nice to hear someone actually checks their extinguishers one in awhile. Now if you at least checked (and change at least once a year) your smoke detector batteries when you changed your clocks you get a Gold star.
/ Fire Extinguisher Checks #4
When you shake that fire extinguisher, do you feel anything moving around in there. This thread made me go check the one I have. Nothing in the nozzle, but it's 5 years old and I guess hasn't been moved or checked in 3 years.:eek: Anyway, I couldn't tell anything moved inside it when I shook it. And I know I checked the smoke alarms once in the past 3 years; guess I better do that again today.:eek:
/ Fire Extinguisher Checks #5
Not trying to derail this thread, but I imagine it would be a good idea to have a fire extinguisher on my Bobcat somewhere. I remember reading about a guy who had some hydraulic leak cause oil to spill on his exhaust system, and it caught fire and totally burned up his mini excavator. What is the appropriate type of extinguisher to keep on a machine like a Bobcat?
/ Fire Extinguisher Checks #6
One of those powdered ABC Types will work. Also called dry chemical.
/ Fire Extinguisher Checks #7
Bird I thought that someone else would have piped in on the extinguishers. I don't feel much moving around in my extinguishers at all when I shake them. I believe that is normal. I even came into work today and shook the ones here in my Lab that I work in. I couldn't really feel the powder moving around in them as well.
/ Fire Extinguisher Checks #8
Thanks, Jim. I think Kidd's website says to check the extinguisher weekly to see if the needle in the gauge is still in the green and to discard the extinguisher when it's 12 years old. Mine is a B C dry chemical extinguisher, but if we had a fire, I'm not even sure I'd remember to use it.:D
/ Fire Extinguisher Checks #9
Gee how many extinguishers older than 12 years old are out hanging on walls and vehicles? I am sure a few of mine at home are older than that. Yes if the needle is in the green that raises the confidence level a little. I do know how to use them from a 3 year stint as a Volunteer fireman. For little grease and junk fires the Dry chems are great. Having one around could save a lot of damage in the long run. As long as the person isn't at risk of smoke inhalation or getting trapped.
I think keeping up the preventative maintenance is good practice and keeping the bugs out of the nozzles :)is a good idea. Also as Medicshawn said them smoke alarms and batteries....
/ Fire Extinguisher Checks #10
I have, in the past homes in which we lived, checked the smoke alarms pretty regularly, but I've gotten lax in my old age. We've been in this house for 3 years. It was built in 1991 and I think had a major renovation in 1999. When I still smoked, I tested the smoke alarms by blowing smoke into them, and yesterday, I checked them by pushing the test button, and they worked. However, I haven't figured out how to open them. I'd sure they are hardwired into the 120 volt system; don't know whether they might have any battery backup, and I hate to destroy one tearing it off the wall to find out.
/ Fire Extinguisher Checks #11
Some twist to open and some have a little push in spot. Think if you get to where you can see them straight on with flashlight you will find the instructions in their molding.
/ Fire Extinguisher Checks #12
This is just hilarious. With a flashlight and magnifying glass, I found, on the perimeter, instructions to turn it clockwise to remove it. Well, that sounded great, but it removes the whole thing, except for a "base" that stays on the wall. And I stil could not figure out how to get it apart to see inside. But it's a "Lifesaver model 1225". OK, I look for that on the Internet, and what do I find. Well, I'm not the only one with the problem. On another discussion forum (allexperts.com), someone else asked the same question and the answer he got was:
Some of these detectors can be like a puzzle box to get open so you can replace the battery.
I tried some research on your detector. It's made by Kidde, but apparantly is an old model, and I could not locate a manual.
I have to say, as I have many times on this venue, that some manufacturers recommend replacing smoke detectors afer 7 or so years. They're so cheap, I can't argue with them.
If you're handy with hand tools, it's not a difficult job. But many folks are reluctant to try. S'okay. Any electrician will be able to do the job in short order.
Smoke detectors are required vitually everywhere in new residential construction. Local electricians usually get this work. So plan on 65-75 bucks for an hour of labor, and about 15-20 each for the detectors
On a more recent discussion, someone said he got his opened (didn't say how) and there was no battery backup. So, once again, the recommendation was to replace it.:(
/ Fire Extinguisher Checks #13
I check many extinguishers at work on a monthly basis (mainly ABC and CO2). On dry chemical one way to check is to turn it upside down and wait a few seconds. You should feel a thud as the dry chemical that was in the bottom drops to the top. Then check the gauge to be sure its in the green. Sometimes you need to tap on the gauge since it might be stuck reading full yet the extinguisher may be empty. Check the hose for no blockage or signs of leakage.
At work ours are also checked annually by an extinguisher company. They also test them every 6 years. They do hydrostatic and full dump and refill tests depending on how old they are. Other types may vary. I have several at home as well and take them in for them to test every 6 years as well.
I don't have the hose plugging insect problem but have seen it. Sometimes mud wasps or other insects will move into the hose and block it off.
/ Fire Extinguisher Checks #14
They also recommend changing smoke detectors after 10 years they should have a date of manufacture on the rear. If in doubt replace them. Cheap insurance.
I would also recommend looking at a water extinguisher (water can). You can find some cheap ones on Ebay. Not good for grease/gasoline type or electrical fires. But for general combustables they make less of a mess and are easily refillable.
/ Fire Extinguisher Checks #15
Those water cans are pretty expensive. Why not just use your garden hose?
/ Fire Extinguisher Checks #16
I have watched the fire extinguisher inspectors check those fire extinguishers for businesses and I believe that it is done on a regular schedule. What I saw them do, was, check the date, and if in date, check the pressure reading, and then they would take a rubber mallet and tap all around the extinguisher to loosen up the powder inside. If the powder did not move at all, they replaced the extinguisher.
/ Fire Extinguisher Checks #17
Now I don't know why I didn't think of that. I have a rubber mallet, so I just beat my fire extinguisher quite enthusiastically, and I can't tell anything moved inside it.:rolleyes: But the needle is still in the green. I may yet have to pull the pin and try it out, out of curiosity, then go buy a new one.:D
/ Fire Extinguisher Checks #18
I forgot about the rubber mallet trick. Bird you be careful you might end up using the mallet on them smoke detectors.. They are a pain though to undo. I take care of my Dad's so that he doesn't get up on the step stool. And I have been replacing them way more often than the extinguishers.. Good point. I have the CO and Smoke detector type upstairs near the bedrooms. Gas furnace and wood stove so I don't want to wake up Dead..
/ Fire Extinguisher Checks #19
Jim, when we were full time RVers, we had a CO detector in the bedroom and an LPG leak detector in the kitchen area in addition to the smoke detector. But now we're in a total electric home and only have smoke detectors. Of course, I think they're both working properly, in spite of their age, and we have the fire extinguisher, actually in the garage, but that's just the other side of the door from the kitchen/dining area. I like the idea of a battery backup type of smoke detector, but I don't know that they're worth the extra cast.
/ Fire Extinguisher Checks #20
I bought a "Explosive gas and CO detector" and both times we had NG leaks at work, it read zero. I dug out the fine print, and it says it detects Propane and gasoline... Seams miss-marked to me.
Our work extinguishers are inspected by the fire marshal and re-tagged yearly around here.
