Fire Department Tractor Rescue Training
   / Fire Department Tractor Rescue Training #21
PoorPlowboy said:
Why not crank the engine, and lift the bucket with the joystick? If it were me under that bucket, I would be begging for it to be off of me in the most expedient method possible.
The reason is the "rescuer" may be unfamiliar with the operation of the equipment and ANY powered attempt to relieve the trapped may end up crushing them further or worse.
Standard procedure would be to chock wheels, take key from ignition, disconnect battery, use cribbing plus airbags to take the victim from the entrapment while having a medical team on stand-bye.
Even though theoretically at first glance it may seem better to just muscle the object off of the victim...
http://www.facs.org/trauma/updatehaiti/pdf/advdismedresponse14-16.pdf
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
