Mowing Finishing Mowing with a 3130
   / Finishing Mowing with a 3130 #11
I have a L3830 with R4 loaded rear tires and use a 72" MMM to mow my yard with. I do not mow when the ground is wet. I think the R4 tires do not cut or scuff as bad as the turf tires I had on the other tractor. The hydro transmission makes turning without cutting, digging in or scuffing the lawn an easy task if you lift your foot. I talked to several professional landscapers prior to ordering with the loaded R4's. They advised they liked the R4's better than the turfs. I can not address R4's not working with a MMM on a L3130. I am sure your dealer can answer this. I was advised the "Galaxy" tires would not work with a MMM.
   / Finishing Mowing with a 3130 #12
Just looked, my gut reaction was that you where right, but sure enough the R4's will not fit with the MMM.
   / Finishing Mowing with a 3130 #13
why does a mmm fit on the 3830with r-4s but not 3130 im asumming that its because the 3830 has wider wheel stance and get it further away from mower im just curious
   / Finishing Mowing with a 3130 #14
frankie14001
The RC72-38 (72" mid mount mower) will not fit any of those (L3130, L3430, L3830) tractors with the R4 industrial tires.
Lewis
   / Finishing Mowing with a 3130 #15
Jim,
It seems like you want the 3130 to do the bigger jobs. May I suggest that you take the money you would have spent on the MMM and pick up a small riding mower for the lawn. If you need to mow fields maybe you could find a used tph mower for not too much money.
Wow! It sure is easy to spend other peoples money. /forums/images/graemlins/cool.gif
Dean
   / Finishing Mowing with a 3130 #16
Have you thought about renting when you need a larger machine and keeping your smaller one? I've rented both an L35 and a B21 when I put on an addition to my house and done several other large projects. The place by me charges about $200/day or something like $700/week and they deliver and pickup the tractor. With an L35 you can dig up enough ground in a week to find Jimmy Hoffa and that same $700 won't even buy you a trailer. And you aren't responsible for maintenance or storage.
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
