Finishing mower vs Ride on mower
   / Finishing mower vs Ride on mower #1
stephan
NSW, Australia
Lamborghini 450 Runner, SAME Tiger 70, Kioti CS2610
I'm thinking of buying either a ride on or finishing mower but at twice the cost and an additional motor to maintain I think just a finishing mower might do. I wonder what others views are on this?
Pro's and Con's of each?
   / Finishing mower vs Ride on mower #2
When you say "Ride On" mower, are you talking something like this?
   / Finishing mower vs Ride on mower #3
I just went through the same thing. I ended up buying a 595x for lawn mowing and I'm going to us it for snow removal with a snow blower this winter. Any how I tried a rear finish mower and my problem was that I couldn't get around my apple trees as easy as I would like and it left me a lot of trimming. I came to the conclusion that if it was all open space with not to many obstacles to go around then it would work great. I must also tell you that I have a L3010 so that alone is big for going around apple trees! One thing that I would try to do is try a rear finish before you buy one. Hope that helps you.
   / Finishing mower vs Ride on mower #4
I faced this dilemna a few months ago. I ended up buying a Kubota ZD21, (zero turn mower). My only regret was not buying 1 years ago. It's cut my mowing time by 2/3.
Thanks guys.
   / Finishing mower vs Ride on mower #7
OK, I'm a little late on this one, here's my view.
I was trying to setup my CUT with a belly mower and before I found all the hardware needed to make that work, I came across a Cub 1872. The cub has a 60 deck and and mows really nice. I paid 2K for the tractor/deck/54 hydraulic snow blade, the tractor had 650 hours on it when I bought it.
I concluded I was better off putting those mowing hours on this much less expensive machine, plus, I've never had a Cub repair I couldn't do myself. You can pickup a 45" snowblower for one of these for 3 to 400 dollars and they do a great job.
I find myself using two tractors on a lot of projects, I'll be moving dirt with the FEL and trailering it somewhere with the Cub.
This past spring/early summer I got the Cub stuck more than a few times and just pulled it out with the 1220. If I'd stuck the 1220 with the finish mower on, it would have required a lot more thought to get it out.
I use the 1220 and RM 59 for a couple of acres of open field and have used it on my lawn around the house when I broke a wheel on the Cub deck, it's nice to have a backup.
The Cub doesn't ride as nice, it burns a lot more fuel than the diesel, but for me this was a good option.
I attached a pic of the Cub movin some snow.
Good Luck
Curt
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A51572)
2004 International...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2017 Ford Fiesta Passenger Car (A51694)
2017 Ford Fiesta...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
