Finished mating my jinma hoe to the Kama!
Well, after a lot of cutting, welding, and head scratching i got the frame mount hoe from my old Jinma 284 mated up to my KM554.
I used a prince pump to make it easy and for greater flow rate and boy i just need to run at idle now!
the worst part of the job was fabing up the front bracket that went tied both loader frames together and had the drop downs to go to the hoe frame. I also made the frame 3 feet longer.
That new plasma cutter sure was handy.....
Now all i have to do is keep those crappy ram line o-rings from blowing out in the worst places. I am thinking of trying to replace the o-rings with copper washers and seeing if they seal up, anyone try this yet?
The chinese need to put an extra 10% effort into these things to engineer them correctly. The seal-loc fittings they use are not proper for this application. A true seal-lock fitting should have the o-ring captured on both the OD and ID but in this case they only have them captured on the OD and the o-ring can squish inward losing clamp and seal. Idiots!
