Finished loader for old MTD tractor
   / Finished loader for old MTD tractor #1
blacksmith
Bronze Member
I finished my loader for my 30 year old Dayton (MTD 990) GT tractor. Here are some pictures.
I removed my hand control and added a foot control. Check out the foot brake as I had to add a "U" piece so I could clear my big foot. I will paint the bucket and add a guard for the pump. I want to add power steering so I will look for a used steering valve.
I tested out the pump when I worked in 90 deg. heat for 2 hours without the oil getting too hot. I moved a lot of dirt in the two hours. The bucket comes off and on very easily with the quick disconnect feature on the loader.
   / Finished loader for old MTD tractor #2
Good job! Steer ok with a full load?
   / Finished loader for old MTD tractor #3
Looks good! I'm envious of your ability.
   / Finished loader for old MTD tractor #4
Nice Job!
I have an old MTD 16hp and have often thought a FEL would be handy..
It does steer hard with a full load and you have to be moving to steer but it gets the job done.
   / Finished loader for old MTD tractor #6
That looks great blacksmith!! what are you using for ballast?
Having a loader makes me wonder what, if anything, would I have accomplished at my place if I was FEL-less!! It is the single most useful attachment, for me, on my tractor!!
(The backhoe is number two. For tools my chainsaws are third on the list, followed by the wood splitter.)
   / Finished loader for old MTD tractor #7
Yep, great job.
Some rear-ballast hanging off the back may help stability and that steering issue.
Thanks for thr pics, good job.
My tires weight 50# each plus 50# of wheel weight. If I need more ballast I plan on building this weighted platform. It is made from 6"sq. tubing filled with sand and adding 1/2" plates as needed. It will be attached on my 3ph. I have all the material all I need to do is weld it together.
   / Finished loader for old MTD tractor #9
Thanks for sharing. Great job.
   / Finished loader for old MTD tractor #10
I have an 1,100 lb hoe on rear, some times it feels like I could use more- that weight box sounds pretty good to me..:)
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
DOOSAN DL250 LOADER (A51242)
DOOSAN DL250...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
