Rear Finish Mower Finish Mower Size
   / Finish Mower Size #1
467ron
Troy,MI
Ford,8n
I have a 1949 8N should that be able to handle a 5 foot finish mower?
   / Finish Mower Size #2
I used a five foot finish mower on a John Deere M, about the same horsepower. It would bog down if I was in very heavy grass, but under normal conditions it handled it well. Don't forget to use an overrunning clutch to prevent the mower from driving the tractor when you push the clutch in.
Pat
   / Finish Mower Size #3
+1 on the overrunning PTO clutch. If you do not know what it is here is a write-up from tractordata.com. You can purchase them from TSC. I got a friend to purchase one and now is NO longer running into things when he is using his rotary cutter on his Ferguson.
TractorData.com - Overrunning PTO Clutch
Hayrack (A50515)
Hayrack (A50515)
UNUSED AGT SDA-140W WHEEL LOADER (A51243)
UNUSED AGT...
Unused Delta Crash...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51243)
2016 KENWORTH T270...
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
