Finish mower size
   / Finish mower size #11
off topic as to the tractor in question - on topic of finish mower size:
Do you think a Kubota L3130 will match up with an 84" rear finish mower for use on mostly level property and grass that is mowed at least every 2 weeks?
Thanks,
Terry
   / Finish mower size #12
I just bought a BEFCO H-40 flail mower. It's rated HP is 15-40 so you should be able to power it just fine. Weight is 548 lbs, can you safely lift that? I have been VERY impressed with the cut. I ran test strips on fine grass and the cut was indistinguishable from our commercial ZTR's cut. Today I mowed a field with native grasses and wildflowers (aka weeds) that were 8-10 " tall. The mow was fast and it never even grunted. The ZTR would have clogged up under the deck very early on which is why I didn't buy a rotary finish mower. Our Bush Hog SQ-84 would have left a rather ragged cut. It's tough but just not a finish type mower.
   / Finish mower size #13
There are 3 different blades available for that flail mower. Two of them do a good job on grass and the other blade is designed for brush. Any flail mower is very safe because all objects are thrown downward toward the ground.
   / Finish mower size #14
<font color="blue"> Do you think a Kubota L3130 will match up with an 84" rear finish mower for use on mostly level property </font>
I would guess that it would do fine. I pull a 72" RFM with my 3010. No problems at all. My property not even close to mostly level. On the steepest hills I have to use low gear to make it up em pulling the RFM. But, on fairly level ground I don't think you'd have a problem. 84" would be more prone to scalping though, for little rolling hills. I have a couple areas I've learned to manuver around a little so as not to scalp.
Moon of Ohio
   / Finish mower size #15
Can a flail mower cut a yard as well as a finish mower? Does it cost more? thanks, bw
   / Finish mower size #16
Brett,
Rumor has it that a flail mower can cut equally as well as a finish mower. I'm not convinced but I'm sure it would cut much nicer than any rotary hog or such. Flail mowers are very expensive though.
Unverferth Perfecta 26' Field Cultivator (A53317)
Unverferth...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2017 FORD F-450 XL BUCKET TRUCK (A57192)
2017 FORD F-450 XL...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
LG TROMM STEAM WASHER WASHING MACHINE (A57192)
LG TROMM STEAM...
2020 KUBOTA KX033-4 EXCAVATOR (A52707)
2020 KUBOTA...
