Finish mower PTO issue with Quick Hitch
   / Finish mower PTO issue with Quick Hitch #1
Jeepnford
NE Missouri
Case DX35
I have a Bush Hog RDTH-72 finish mower I'm trying to use on a quick hitch. The problem I'm having is the lift pin brackets "float" up and down about 4 inches or so. When the pins are up there's plenty of clearance. When the pins are down the PTO cover rubs on the QH. I have a top link adapter on it. I was thinking about drilling and putting a bolt so the lift pins on the mower were fixed in the up position. Would that cause issues with the mower following ground contours or other issues?
   / Finish mower PTO issue with Quick Hitch #2
I had the same problem with my 72" Farm King mower. I did 2 different fixes. One I notched and reinforced the top cross piece of the quick hitch so that the pto shaft had a few more inches of space. Secondly the lower arms on the mower had stops welded onto the mounting slot so that they could no longer drop to the bottom of the slot they were mounted in. The lower arms could still move up and down but no longer had the factory range of motion. I never experienced any problems with that modification.
   / Finish mower PTO issue with Quick Hitch #3
Does it rub hard enough that the guard pushes into the PTO shaft?
Metal Rooster Statue (A55758)
Metal Rooster...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
New/Unused Quick Attach Auger with Bits (A54865)
New/Unused Quick...
Giyi Stump Grinder (A53316)
Giyi Stump Grinder...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
