Rear Finish Mower Finish mower not cutting right
   / Finish mower not cutting right #1
goatherderbo
I was mowing a field yesterday, and my finish mower kept leaving a 2-3 inch wide path of grass in between the right side and center blade. The field was fairly high, maybe a foot or more in some areas, but the other side did completely fine. I checked underneath the mower to see if the blades just didn't overlap on the right side, but everything looked the same on both sides. Is there something I should tighten or adjust, or is the problem in the blades? The belts are adjusted to the same tightness for both sides too.
I have a Kioti KRM03-72
Thanks
   / Finish mower not cutting right #2
Thanks
were you mowing too fast?Given you said grass was a foot or so tall, thats very long grass for a finish mower to handle.Try at a lower ground speed and see if that helps,it,s usually something simple.:thumbsup:Dave
   / Finish mower not cutting right #3
Is it possible your tractor tire may be compressing the grass? If that strip of grass is inline with one of your tractor tires, then slow down a bit (so the grass can recover and spring back up). Also, will it leave the same strip when reversing?
If the tractor tire isn't compressing the grass, and reversing doesn't cut the grass, I'd guess you may have one standard and one high lift blade.
Let us know how you make out!
   / Finish mower not cutting right #4
Can't beat the advice given so far.
Did you check the blade bolts? I had this happen to me once. It mowed fine in short grass, but slipped in the taller stuff.
Might want to check belts too.
   / Finish mower not cutting right #5
You are going to think this is absolutely crazy, but we experience this with zero turns from time to time. Typically what we find is the belt pulleys are worn along with the belt (belt slippage). A quick change of pulleys and a tension spring and you are usually good as NEW. Depending on how new your mower is, you may just need a belt change. Approx $30.00 to $40.00 I think. I didn't look up.
Now for cutting the grass and it being a foot tall, you are going to have to go slower than normal to keep the "blade tip" speed up. Your belt could still slip though.
The blade bolt 'loose' is a very good possibilty too. Remove and reinstall with locktite.
Tony
   / Finish mower not cutting right #6
to approach it from a different perspective, its also quite possible that in such tall grass the left and center blades are moving so much grass under the deck that its overloading the center/right blade ability to discharge cleanly. Think in terms of when mowing grass thats a little tall and wet, how a mower sometimes doesnt discharge cleanly.
I'm thinking its possible its nothing more than a grass volume issue.
Does it mow and discharge without problems in shorter grass?
   / Finish mower not cutting right #7
Finish mowers are not really meant to mow 1 foot deep grass.
You are trying to mow to much grass to fast and slipping the belts.
   / Finish mower not cutting right #8
Good point!!
I'd missed the height of the grass before my first response.
Goatherderbo should raise his mower to the maximum height for the first cut (maybe he did), then cut it agan at his desired height.
My Befco manual does not recommend cutting grases higher the 10".
   / Finish mower not cutting right #9
That's very true but most of us our guilty of doing that at one time or another.
With all the other likely suspects mentioned there is one other thing. Modern decks are designed with cowlings to help lift the grass to cut. If they are plugged full ...well the deck just can't do the job it was designed to do. So try scraping the grass from the underside of the deck and note any improvement.
Very surprising to hear that even running slow enough with the proper rpm's this problem could happen even with a plugged deck...but it's worth a shot.
   / Finish mower not cutting right #10
At only 2-3 inches uncut, I don't think the problem is blade slippage, as there'd probably be other symptoms such as very rough/eradict cut over the entire blade. Probably more likely with the grass so tall, the 2-3 inch area is getting pressed down or blown over and slipping between the blades or not getting adequately picked up.
The solutions proposed so far, slow down or cut in two passes are your best bet, unless you wish to keep the area cut lower all the time.
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2012 INTERNATIONAL LF687(INOPERABLE) (A50854)
2012 INTERNATIONAL...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
