OK guys. Thanks.
Here's an update followed by some replies to your posts.
Ran down the road and borrowed a metal detector (I traded it to him for some skidsteer work).
I swept between the farthest tank and the house.
With the sensitivity at its highest setting I found some spots that got a hit and marked. The spots are pretty small (about 8" or so) so I don't think it's the pipe between the tanks.
I then turned the sensitivity way down and re-tested. Only 2 got a hit. It works out that they're in a straight line with the exposed tank and almost equal in distance apart (just under 15') but the line is parallel with the back of the house and about 6-8' out.
Do you think this is the top center of the lid or what? I'm thinking of doing the rebar/hammer routine on that spot. Am I close?
</font><font color="blue" class="small">( bc, you might try calling your county health office. If septic inspections are required where you live, they may have a sketch on file of where it is. )</font>
44trxfun - Except for renewing my carry permit, I try to stay from the county government. Like Moon noted, it normally gets me into trouble.
</font><font color="blue" class="small">( bczoom, When I did mine I took a short piece of re-bar and small sledge and used it as a sonar detector cause when you hit the tank or lid it makes a distinct sound (also stops cold))</font>
Nasty135 - That was going to be my initial plan but also why I noted the surface being packed stone. Wasn't sure if I'd be able to get down to it.
</font><font color="blue" class="small">( Probably too late for this solution but in the winter the snow always melts above the septic tank first. Sometimes I get a very precise rectangle outline through the snow.
Right now, it's the area with the greenest grass as the soil is warmer there. )</font>
Rob, I've kind of watched but never noticed any melting in the winter. Nothing different in summer either (grass)
</font><font color="blue" class="small">( "There are 3 and I need to find 2 of them "
Why do you think there are 3 of them.. I have seen a separate grease trap before(right next to house).. but 3 tanks in a row.. what would be the purpose.. more capacity? )</font>
Kensfarm - The guy that did the excavating for the house has done some work for me. He remembers putting 3 tanks in but didn't recall exactly where.
</font><font color="blue" class="small">( The piping going to your tank should be metal you can use a metal detector to follow the pipe and when it STOPS beeping you should be over the tank )</font>
DaMadman - I thought like Richards that mine was sched 40 as well.
