Finding property lines
/ Finding property lines
MikePA said:
Our standard practice was to put a large head nail, with bright ribbon under the head, in the middle of the road as well as offset stakes at the edge of the road right of way.
When they repave the road I guess forget it.
/ Finding property lines #22
You might be able to get the property line surveyed for what you'll pay for a metal detector.
The fence company will ask you where the line is and, no, they would not order a survey.
Mike, I think the fence company, just taking someones word for it, could cause some real messes.They must have a waiver to sign so they don't have to move it again free if someone complains.
$450.00 for my little 2 ac lot in Maryland.
/ Finding property lines #24
before I wold put a fence up, or hire it built I would have a survey done- after all of the dicsussions about property line issues, it would see like good insurance.
I do agree but IF I but a detector for the $450.00 and IF I do find markers all is well and I get to keep the detector.But if I don't ...well another $450.00
/ Finding property lines #26
bones1 said:
Mike, I think the fence company, just taking someones word for it, could cause some real messes.They must have a waiver to sign so they don't have to move it again free if someone complains. $450.00 for my little 2 ac lot in Maryland.
Yes, it could cause a mess, but it'd be your mess not theirs because they'd be installing the fence where you told them. $450 for your entire lot, what about just establishing the line in question.
/ Finding property lines #27
You can't just look for markers. First you have to know what you are looking for and you need a legal description for that. Randomly finding a marker doesn't do you any good as you won't know what it represents. It may be an offset to a corner or a random point on line or??
You can get the legal description from the town or it may be with your house paper work. It may be a map or in text. Don't use a tax map.
IF the property corners have been set there is a good chance you won't need a metal detector to find them. There may be evidence on the ground which helps find the corners. You may be able to guestimate using the legal description. At minimum you will need a measuring tape. What makes you think the property corners have been set??
/ Finding property lines #28
Metal detectors get expensive if you want them to spot silver/gold. I have saved more money in finding lost tractor parts than it cost. If you are sitting on 2 ac, you can find those pins! Once you find your pins run a string. Ask your adjoining owners to help give an idea where they might be.
/ Finding property lines #29
Just don't ask the neighbor whose shed you think is on your property. :p
The fence scenario was hypothetical,I don't want a fence.Zeuspaul, your right,what makes me think they're marked. I'm in a subdivision built in 1974 they may not have put in markers for all I know.I will take the advice here and check the land records as that seems to be the only correct way to ascertain my borders.
Thanks again for your replys.
/ Finding property lines #31
I'll bet the pins are there. they often drive them in the ground a few inches to your lawn clear.
Land records will not do much good if you can't find the pins. If some one down the street has a fence on their line, then you can use their street side measuremnts to get back to your corner. But even then you will only know approx where to dig. I wounder if a rental store has metal detectors? It will be the fastest way to look. Otherwise prepare to dig a 5' circle.
/ Finding property lines #32
You can buy a fair metal detector at Walmart for a hundred bucks that will find the pins if they are there. You can also spend hours wondering your land finding all sorts of junk with it too!!!
Look for old surveyors tape. It's usally tied to the pins, but half buried and faded over time. It something you can walk right past a hundred times without seeing, but when you look for it, you'll see it. Or that's been my experience. hahaha
Good luck,
Eddie
/ Finding property lines #33
If it's a sub division there is probably a recorded map. You may be Lot *x* of map XYZ. How big is your lot and how big was the land it came from? Are there a bunch of lots very similar in size? Is it like a city block with a bunch of homes with 75? feet of road frontage? Sidewalks? Or is it a large odd shaped parcel divided into a few larger pieces of land? How far away are the street intersections?
Zeuspaul
/ Finding property lines #34
Eddie,
your right there, junk all over near roads. What I hate the most is pull tabs. It sets off the bugger like you found a silver doller. My metal detector has the ability over look steel to some point. I like to take a 8 p nail and my ring and put them on the ground 2' apart. I adjust untill it won't pic up the nail. He could also make adjustments in a 'clean area' by pounding in a pc rebar.
Ok. Got a recorded plat drawing and I can't decipher it.
N84 19' E 112.09' This is where the property meets the street in the front.It also has R=275.00' L=33.41????also 25'brl
It states "unless otherwise shown hereon, lot corners have not been set with this survey.This plat is not to be relied upon for establishment or location of fences,garages or other existing structures.
How can I determine what the "OTHERWISE SHOWN" is.There are little circles located at each corner where the lines intersect could these be the "otherwise shown "markers? Sorry plat didn't come with instructions.
/ Finding property lines #36
Each property line should have a number in a similar format to N84 19E 112.09. The NxxE is the direction of the line (represents an angle) and the 112.09 is feet along the line. Other lines may have a NxxW or SxxE or... N89 19E means 84 degrees and 19 minutes clockwise of north which is almost east. You have to determine where the 112.09 starts and ends...probably the circles. Are there circles at the limits of your property? Sometimes there is a legend indicating what the symbols mean.
Is the 112.09 the width of your property along the street?
R is the radius of a curve. L is the curve length. You'll have to give me more hints for 25' brl??? Does the road curve in front of your house?
You may have a tax map. *real* maps would probably not have the disclaimer *This plat is not to be relied upon for establishment or location of fences,garages or other existing structures.*
/ Finding property lines #38
IF you decide to go with a surveyor call around to all of them prices vary by 200% in some cases for a LPS. So it pays to spend an hour on the telephone.
/ Finding property lines #39
I don't know about where you fellers live, but around here in the Ozarks, land hasn't been surveyed in over 150 years. If a landowner brought in a survey team, his neighbors would have a heart attack.
Last year, the USGS surveyed the Arkansas / Missouri state line for the first time in well over 150 years, there was some very worried landowners around!!!
Down here when you look at acreage, it's "that big oak tree is the north boundery, theres a fence post on the south west boundery" etc etc.. Thats why Real Estate Agents advertise 40 ac "more or less".. or ML.
/ Finding property lines #40
Interesting point.
Here in East Texas, there is a group of investors that have had some land surveyed and found that there are some huge discrepancies. It seems that the mineral rights might not be accurate and the land people thing they own and have payed taxes on for decades, might not actualy be theirs. There is about 4,000 acres in question that the courts are trying to decide what to do with. It's a mess.
Back in California, I have a friend who owned land that bordered some Park land. It was a never ending battle with them and their desire for his land and his pleasure at fighting with them.
There is a developer that for some reason, they really like. He has the Park land surveyed and discovers pieces of land that nobody owns. He then goes through the process of aquiring this land and developing it with multi million dollar spec homes. To give you an idea of how connected he is, he's building these homes on land that the voters passed a proposition to create open space on. No development on it of any kind. Somehow, he has permits to build these homes that pre-date the passing of that bill. What's really amazing is his permits also pre-date his surveys and aquisition of the land!!!
One of many reasons the original Spanish Land Grants in California were disolved, or taken away from them was the lack of an original survey and/or the boundries no longer exist. Rocks, trees and even creeks move and when ownership of these lands were challenged, the courts used the lack of these boundries to justify there desisions.
Eddie
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
John Deere HX15 Batwing Mower (A64047)
John Deere HX15...
2016 CATERPILLAR 259D SKID STEER (A64279)
2016 CATERPILLAR...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
