Finding drain tile
   / Finding drain tile #1
Hooked_on_HP
Veteran Member
Coal City IL
Ford 1900 FWD Kubota F2100E
I know my property has drain tile, but I am not shure exactly where they are. I think a couple of them might be pluged with roots or sand. Does anyone have an easy way to find them without digging a lot of unnecessary holes,which I have already done.
Bill
   / Finding drain tile #2
Video snake. Not only can you see where or if theres blockage, you can use a detector from the surface to find where the tile is and its route, then mark exactly where to dig.
Call your local rentals or look for a contractor. Will save much money and work from digging un-necessary holes.
   / Finding drain tile #4
If you have an idea of where they are, you can get a fiberglass "T" probe from plumbing supply house, or make one yourself.
It is about 4' long with a 1' handle that makes the T. It is a simple probe, since most drain tile is burried in gravel you can usually find by probing in the area.
   / Finding drain tile #5
Try a coat hanger before you spend much money, this really works for me. Try it where you know a pipe is buried to check it out.
WikiAnswers - Is there a tool or device that can detect or find under ground water lines that do not have a magnetic strip
Dowsing
dowsing (a.k.a. water witching) - The Skeptic's Dictionary - Skepdic.com
Web Exclusive! Water Witching How-To - Feature Articles - Point of Beginning
Ranks right up there with predicting the stock market.
Some people can, some can't.
Don't dig based on it.
2007 Ford F-350 Stakebody Flatbed Truck (A51692)
2007 Ford F-350...
2014 Dodge Avenger Sedan (A53424)
2014 Dodge Avenger...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
Ford Super Duty Pickup Truck Bed (A52377)
Ford Super Duty...
