MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,711
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Well, after 3 months of doing next to nothing with the new 3215HST at my Moms and over at my Brothers place, I finally got to put it to work, out at MtnViewRanch.
It looks like it will be quite the little work horse. I have made a few changes since purchasing, added liquid to all 4 tires, put on a hydraulic tilt link, mounted a double valve control. Been waiting for some plumbing parts so that the valve can be all plumbed up, then those will be for the "TnT" and the factory remote will be used for attachment hydraulics.
Put about 14hrs on it the last 2 days. Graded, and moved some dirt with the Gannon roll-over box blade. I liked that it will cut & pull a full 66" wide box blade up hill. Used my 60" road grader, mainly just to see if it would pull it, seems like it will be good, but it will be nicer once I get my hydraulic top link installed. Rototilled weeds that have about taken over where I have some trees planted.
Moved about 40 cubic yards of soil with the loader to even out an area that, well that I wanted evened out. I should have used the 7520 for that, but wanted to see how the new machine would do, it was good, just took 3 times longer.
Put some water lines in and so I used my JD middle buster for the main feed line, mine is a little bigger than the ones you usually see at the stores. It is 36" wide at the top, and will put a ditch in 19" below ground level, 10" wide at the bottom.
Anyway, here are a few pics to go along with this. Oh, I am very happy with the 3215HST, it performs well and is very nimble, at least to me.
