Finally Tubed My Mower Deck Tires... 16 years
   / Finally Tubed My Mower Deck Tires... 16 years #1
MossRoad
Super Moderator
South Bend, Indiana (near)
Power Trac PT425 2001 Model Year
I finally had enough. Ever since I got my machine back on 2001, I've been dealing with flats on the pneumatic caster tires on the mower deck, snow plow and brush cutter.
I changed the brush cutter tires to solid tires about 2 years into it. So that was no longer a problem, and left me two spare pneumatics. The seal on the pneumatics just doesn't seem to hold past 1 or 2 mowing sessions. I'd resorted to just swapping the solid casters onto the mower deck and plow for the season, and just "borrowing" them back for the brush hog 2-3 times a season.
Well, I lost a wheel bearing on one of the solids, and finally figured it was time to tube the pneumatics. So I bought two tubes and put them in today and mowed the lawn. I'll probably get two more and tube the ones for the plow sometime before winter, and pick up a couple new solids when I get the chance.
   / Finally Tubed My Mower Deck Tires... 16 years #2
I also had tire leaks but it was the actual tractor tires. Eventually tubed all 4. I think my mower tires got Slimed...seemed to fix them for me. Tried Slime in 2 of the main tires and the tire shop guy wasn't happy to see that when he went to tube them :(
   / Finally Tubed My Mower Deck Tires... 16 years #3
yep I have slimed all my tubeless tires and finally replaced my old wheel barrow with a two wheel one with flat free tires on it.
   / Finally Tubed My Mower Deck Tires... 16 years #4
That is some perseverance on your part.
My ground is so uneven and hilly that i had a tendency to push the the tires off the hubs and the thorns would puncture the tubes and i was also tearing the valve stems off. I took your advice and got square profile solid tires and that really made a big difference. Also bought a tire mounting cone thats used to mount the solid tires onto the hub.
   / Finally Tubed My Mower Deck Tires... 16 years #5
I tubed all the front attachment tires. Great move and no problems since then.
   / Finally Tubed My Mower Deck Tires... 16 years #6
Yes sir, sometimes you just need to bite-the-bullet and rid yourself of petty annoyances. Life is so much sweeter.
JOHN DEERE WHP48A LOT IDENTIFIER 98 (A53084)
JOHN DEERE WHP48A...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
2018 JOHN DEERE 5075GN LOT IDENTIFIER 91 (A53084)
2018 JOHN DEERE...
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
(INOP) FORD 8N / 9N TRACTOR (A51247)
(INOP) FORD 8N /...
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
