Finally towed the BX23
   / Finally towed the BX23 #1
PA452
PA
Kubota B2650
First time towing the Kubota BX23 with FEL and BH (2700# dry weight) today. I figure the gross weight of the trailer with payload was 4500-4600#. I took it slow. Wasn't sure of what to expect pulling with the Tacoma. In the end, I was pretty impressed. I upped the boost setting on the control one level. Stopping was no problem, trailer brakes felt just right. The Tacoma had no real issue getting the trailer moving, even on some steep hills. On a steep driveway that was recently tar/chipped, I did spin a bit at one point. Maybe needed just a hair more tongue weight. It pulled and rode very nice, I think nicer than a single axle trailer with a much lighter load.
Pics...
About to load up for the first time. I didn't bother blocking up the rear of the trailer today, thought I'd see what it does. For a moment when the tractor was on the far rear of the trailer, it certainly does lift the rear of the Tacoma up a little; not to the point of being off the ground but up high enough that if I was loading/unloading on a hill I'll definitely be blocking up the back.
Loaded:
Chaining it up. I have two 20' long 5/16" chains. I wanted a 4-point tie-down. Rather than chop the chains, I picked up four hooks and some hair pins. I attached the hooks at points on the chains to get a 4-point tie-down without chopping the chains. What I really like about this is that for moving other things, I can always move those hooks to other positions. This is why I got the hair pins for the clevis pins on the hooks, as you can see in the pic. This way I can easily move them around.
Loaded and chained:
Took it over to the property briefly, just for kicks really. Used it to push a couple dead trees that were covered in poison ivy off the trail in the back. Not much else to do there at the moment.
Loaded back up, ready to head back home.
   / Finally towed the BX23 #2
Nice job with the chains and binders. I don't see a strap on the FEL or backhoe. You should have one on each. Just but the backhoe bucket on the deck of the trailer and strap it down. What are the Tacoma's rated to tow? Your rig should be no problem. Nice setup.
Thanks. That Tacoma's tow rating is 6500#, so I still have plenty of margin there. A lot of people on the Tacoma forum talk about towing loads around this and say they will never do it again or they wouldn't want to do it far. Then again, others say they tow well north of that number frequently without issue. I think a lot of them are towing travel trailers though; whole different ball game with all the air those things must catch. I really didn't know what to expect, but I was quite happy with the way the Tacoma pulled it.
   / Finally towed the BX23 #4
Best to chain that backhoe bucket down on the deck while trailering.
2007 GMC C4500, Cab and Chassis, 4x4, Duramax (A47371)
2007 GMC C4500...
2010 RS Godwin Body Tri-Axle Dump Trailer (A46683)
2010 RS Godwin...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A48836)
2003 Isuzu NPR-HD...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A48836)
2007 International...
Coral Panels (A49339)
2014 Chevrolet Tahoe SUV (A46684)
2014 Chevrolet...
