Finally starting an addition on our shed
   / Finally starting an addition on our shed
I love my 26' ladder, super light and easy to move around. I dread when I have to work on something it won't quite reach and I have to drag the 32' out, it's heavy and hard for me to move around alone.
I used to do a lot of landscape lighting and did a lot of down lighting from 50' or more up in a tree. Sometimes I could do that off a lift but, more often I had to strap on the climbing gear and do it literally hanging from a rope to get the fixture exactly where I wanted it. Doing that, I got to where I'm not bothered by heights at all anymore. Once you get used to it, it's nice to get that far off the ground and just sway in the breeze, the perspective and view is pretty and it's quiet, even when you're in town.
   / Finally starting an addition on our shed #192
I see that you are working on your dump truck. Does that mean the addition is done?
Not even close. We're still hanging drywall, life keeps interfering.
Eddie, you want to come finish hanging the drywall for me? I'll feed you, send you home with fresh pork and vegetables and provide you with the satisfaction of a job well done! :)
   / Finally starting an addition on our shed #195
If you just give me another 20 years to retire, that sounds like a great offer!!!!
So, life slowed us down again and I was in an auto accident last month that I sustained some spinal injuries that have left me with pain, numbness and other issues (I can't really discuss it further yet) but...our daughter has decided she doesn't want to be in Cypress anymore because she misses us and is just lonely in general. So, when the apartment lease is up in December, she's moving here which means we can't screw around anymore, we need space for her.
Drywall is coming along, very slowly though it's still forward momentum. I've just about got the upstairs done, still a little bit of plumbing to finish up, punching the vents into.the attic and the male adapters for the valves, and we can finish up the bathroom drywall. The tub is getting delivered today so we can get that placed to put in the backer board.
I plan to finish up the stairwell drywall, then build the stairs and then do.the downstairs ceiling and walls. I'm.doing electrical finish work as the drywall goes up so it's done and we're going to hire put the float, tape and texture. We could probably do it given enough time, with our new hard deadline though, we decided it was best to just pay to have it done.
The inside is starting to look like a house now. We're hoping to have the addition complete by October as we still have to move a couple of walls in the original shed to create an eclosed bedroom for our daughter once the ingress/egress changes between the 2 buildings are made. IMG_20180611_151619048.jpegIMG_20180611_151603215.jpegIMG_20180611_151555007.jpegIMG_20180605_093030578.jpegIMG_20180516_101006058.jpeg
   / Finally starting an addition on our shed #197
Sorry to hear about the accident. Hope you have a full recovery and it doesn't interfere with your business. That's one of my all time fears, not being able to physically do my job.
Nice to see that you cut out the windows from the sheetrock. Next time you hang it, try to go horizontal. Just like laying plywood for a sub floor, you get more strength and a nicer finish by crossing as many boards as you can. With taller walls, you put one sheet up high, another down low, and then rip a thin piece for the center.
Yeah, I haven't really worked much since the accident and when I have I've really paid in pain. I didn't collect anything in May after it happened because I couldn't physically finish the product.
We had a lively debate about which direction to hang the drywall and settled on vertical because:
1 It leaves fewer tape seams and puts the horizontal seam below eye level.
2 How much sheer strength is 1/2" ultralight drywall really going to add over the OSB and metal siding.
3 It's physically easier with the injuries to do it vertical.
On 8' or shorter walls I've always gone horizontal but, for those reasons we decided on vertical this time.
Started the stairs. Our rise is 9 3/8 because we don't have much run space and we both prefer a taller step.
Winder stairs next and then the other set of stringers, hopefully finish them this week, it'll depend on my pain levels.IMG_20180903_192353099.jpeg
   / Finally starting an addition on our shed #200
Winder stairs next and then the other set of stringers, hopefully finish them this week, it'll depend on my pain levels.View attachment 569661
What are the stub outs under the stairs for? World's smallest bathroom? ;).
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
Kubota M4700 51HP Utility Loader Tractor (A55787)
Kubota M4700 51HP...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
40' High Cube Four Multi Doors Container (A47477)
40' High Cube Four...
Freightliner Tender Truck (A55301)
Freightliner...
2020 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A56129)
2020 VOLVO...
