Finally purchased a 4200 hydro 4 wd with 420 loader
   / Finally purchased a 4200 hydro 4 wd with 420 loader #1
lutt
Platinum Member
Pocahontas, Arkansas
Kubota ZG 22, John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
Well, after much debating,looking and figuring. My wife and I purchased a 4200 tractor with a a 1000 hrs. Also a 48" bush hog brand bush hog, finish mower, and box blade. I will be using it to clean up this springs logging mess, deer food plots,maintain roads, and some jobs on the side. Any advise/input would be appreciated. Thanks. LUTT
   / Finally purchased a 4200 hydro 4 wd with 420 loader #2
Good luck with the 4200.
The 4x00 series were good machines. The only thing I've ever read bad about the 4200 itself is it's a bit low on power for the size and weight. You'll know soon enough how well it works for you. Mostly, you may have to use a lower gear or range for some work.
   / Finally purchased a 4200 hydro 4 wd with 420 loader #3
I've got an 01 4200. As long as you know it's limitations you'll be fine. I use mine mainly for loader work and it's done everything I've asked of it and then some.
Congratulations
John
Thanks guys,I was thinking of adding ballast weight to the rear tires,probly in liquid form. What I found is that it gets around well in the woods and seems to be quick moving dirt with the loader. I have bunched some tree tops with it and seemed to do well for that. The tops were left from the fire wood that we have cut. Thanks LUTT
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
TRUCK FLATBED (A52472)
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
40' CONTAINER (A51244)
