Finally & Officially Done Power Rake
   / Finally & Officially Done Power Rake #11
I was gonna respond saying "Everything has a price...You're only over the hill and thru the woods from me; show up here in the fall with a fist full of cash and you very well could have it" but then I remembered how much time I have into this....:eek:
So does that mean that you're taking orders?:D
   / Finally & Officially Done Power Rake #12
Wow...nice high quality build!
   / Finally & Officially Done Power Rake #13
looks good. I just finished my power rake today. I posted some pics of mine when I started my build. Mine does not look as profesionally built as yours, but sure works nice. You did a great job! How fast do you have your drum turning? Greg
Thanks...You did a nice job as well!
Drum Speed....Gearbox is a 2:1, and I have a 16 tooth driver, 18 Tooth Driven sprocket for a slight reduction there as well...According to my math that makes the drum turn at +/- 240 RPM.
Question about yours? Why did you go with so few teeth?
   / Finally & Officially Done Power Rake #15
Dave, first off impressive job it looks 100% quality. After owning a harley rake for a year now let me make one suggestion. I'd move yout slip clutch to the other side of you gear box. Reason being you want the clutch to slip before it harms the gear box. Especially in the rock garden of NE we call home. I got lazy this year and didn't maintain my clutch this year and it didn't slip which in turn was a $450 repair and down time. Please head this warning on this one. I'd hate to see you hard work sidelined. Otherwise great job!!:D
Matt
   / Finally & Officially Done Power Rake #16
That's not a project...its a masterpiece! I am bowing before your skills. WOW!
Peter
Matt
Thanks for the kind words!
Funny you mention the clutch issue... I debated it for 2 months as far as where to put it...I actually bought the clutch setup to go where you mention (smooth/smooth shafts, I had keyways machined into both ends, I could swap the clutch over to where you say in the time it would take for me to cut that top driveshaft from the gearbox to the chaincase). The reason I didnt put it there is 2 fold....A) this clutch is a single disc eurocardan clutch, not rated to take the torque on that side of the gearbox...by decreasing the speed 2x, I increase the torque 2x...I would have needed to get a larger/multi plate clutch. Which also translated to serious money because there are no "generic" clutches like that... B) The Gearbox is a serious gearbox, its an industrial Gearbox..made in the USA by Browning, actually even has provisions to plumb it into a circulating oil system :), its rated for 100% Duty Cycle with no oil circulation to 85 horse, so translated into a duty cycle such as this that makes this GB rated to 120ish HP. My thought process is that if something were to go horribly wrong, I'll be fixing something other then the Gearbox...this came to thought as well.... why is it all tillers have the clutch on the input side of the gearbox? IMO a tiller is much more severe duty then a power rake.
I'm treating the power rake as a finish tool...I've heard stories of people passing a harley on their 15 year old gravel driveway thats as hard as concrete...in a case like that, yeah, I would want the clutch where you mention. I dont see rehabbing my existing lawn or passing it over the loam I spread with my BB being too hard on it.
   / Finally & Officially Done Power Rake #18
Sounds like we are running about the same speed. I am thinking of switching my sprockets to gain some speed. As for the number of teeth, I have doubled the number of teeth since I took pics of mine. I will post pics of mine now that I am done building it. I plan to take my rake apart this weekend to sandblast and paint it now that I know it all works as planned
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2005 Freightliner M2 106 Ambulance (A56858)
2005 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
