Chipper finally joined the Wallenstein crowd yesterday
   / finally joined the Wallenstein crowd yesterday #1
tree farmer
X-treme NW Orygun
2740 Montana;3414 IH;TD-14 IH
Well, after a couple of years looking at mostly Chinese 3 pt. chippers, (yeah, my wallet was squeaking:laughing:) I came home yesterday with a Wallenstein BX42R, which was the one I had hoped to get 2 years ago until I found out the price. I really felt I needed a power feed of some sort due to the forked branches on the Spruce, Fir, Cedar, and Alder on my tree farm. So far I'm glad I went with the BX42. Kind of hard to justify $2100.00 extra for the hydraulic feed, but at 65 years old, I gotta have all the help I can get and both the tractors have remotes, so why not? My dealer had this on his lot for a couple of years, but I guess no one around here wanted to spend 5 grand plus on something they would rarely use. I finally got it for $4200.00, so I'm happy. A little paint fade and a few scratches, but still unused. I went through it and checked all the bolts, greased the bearings, and set the bed knife (it was WAY out) last night. Started out this morning on several acres of spruce and fir prunings, only to find it doesn't like small green limbs and twigs. The chipper worked fine and didn't seem to slow down much at all, but the discharge pipe would plug no matter what speed the infeed was set at.:confused2: There is a lot of sap (think sticky pitch) in fir and spruce this time of year, so that might be an issue also. Worked like a champ on the stuff that had been on the ground awhile and also was great on fresh cut alder and cascara. Guess I'll have to wait awhile on the other stuff. I was running the 2740 Montana at about 2200rpm, so that was about 450 or so on the pto. The hydraulic feed on this thing is incredible. I fed it lots of 2"-3" alder and cascara saplings that were probably 15-20' long. Stuff the butt end in the feed rolls, and it would fold the limbs in and chip the whole thing without hesitation. Seems very well designed and built with quality materials, easy to service, parts are readily available, bolts are all SAE., and I feel much better about working around potentially hazardous equipment if it isn't made in China. Best part about this purchase was the wife was all in favor of it since it was made in Canada and it matched the tractor.:cool:.....Dan
   / finally joined the Wallenstein crowd yesterday #2
I have a BX62 and the shear bolt in the PTO shaft is metric, might want to check yours.
Thanks, that's one bolt I did not check. Gonna do that before I need one....Dan.
   / finally joined the Wallenstein crowd yesterday #4
I have a BX 42 (non hydraulic) that works great for me.
I have found that leafy stuff I just let lay for a week or ten days and then chip it.
By that time it has dried enough that plugging of the chute is a non issue.
   / finally joined the Wallenstein crowd yesterday #5
Zebra I am contemplating a BX62 for my machine. I have 45 @ pto what are you running it with?
   / finally joined the Wallenstein crowd yesterday #6
I have a Wally BX42S PTO chipper, the model without hydraulic feed, powered by 25 PTO horsepower. A good match, chipper rotor never slows down under load. I concur with "texas42" that letting brush dry until leaves are crisp/dehydrated rather than green reduces exhaust chute plugs, which are infrequent events; however plugs do happen.
I keep a 28-volt battery powered Milwaukee Sawzall with me in the woods, usually with a nine inch reciprocating blade. This tool is the berries for removing plugs. The blade slips right in the mess, hit the trigger, and the plug drops out in chunks.
I use my tractor's bucket and a clamp-on Bucket Solutions Bucket Spade to remove brush and weed saplings BY THE ROOTS. I then use the Sawzall to amputate the roots and larger side branches before chipping. By removing roots and concomitant dirt chipper blades stay sharp longer. Side branches go through the chipper, roots go to the burn pile.
Tractor Forks, Bucket Forks, Loader Forks
   / finally joined the Wallenstein crowd yesterday #7
Nice chipper! If you can afford it, the Wallenstein's are great machines. I want to get a BX62 but the price is a tad prohibitive!!!
   / finally joined the Wallenstein crowd yesterday #8
I run it on the John Deere 2030, 60 PTO HP.
   / finally joined the Wallenstein crowd yesterday #9
Very first thing I chipped was the brush/leaves from a storm downed cherry tree. Plugged the chute. Now I wait until the leaves fall off. Also if doing a lot of small stuff ever so often send someting bigger thru :thumbsup:
   / finally joined the Wallenstein crowd yesterday #10
I chip a lot of brushy and leafy stuff and a bunch of very small twigs (prunings). I've found that if I put a larger woodier branch through regularly while I'm doing that, that I don't get any clogs. I think the extra wood going through pushes out any of the leaves etc. Its a great machine, I think you'll find you use it a lot (I know I do!)
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 FREIGHTLINER...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
2019 Chevrolet Silverado 2500 4x4 Warner Service Truck (A55852)
2019 Chevrolet...
