Tiller Finally bought Kubota B3200HSD. Now I need a tiller. Suggestions?
   / Finally bought Kubota B3200HSD. Now I need a tiller. Suggestions? #1
Nanook
Buckingham, Pa
Kubota B3200 HSD
I've been shopping for a new Kubota tractor for a few months. I finally bought one, just in time to still get the 0% financing. I bought a B3200HSD with FEL and BH. Now, I need to buy a rototiller for it. I definitely want a reverse rotation tiller. At the present time, I don't have a huge food plot or garden, and the tractor only has 23 pto horsepower (32 hp overall). I believe the tractor is about 58 inches wide at the rear tires. Some have said that I need at least a 60" tiller. But, others have said that if I go to 60 inches, I need at least 25 PTO HP. 23 hp is close, but is it close enough? I don't need to do the work in record time. In fact, from a time point of view, even a 40" tiller would be fine. But, I've read that if you don't get a tiller wider than the rear tire width, it will not work well. In that case, you need a tiller that can be offset. I see the Phoenix T-4 series can be offset, and the price is reasonable compared to a 60" LandPride. I am also considering a 52 inch, or 60" Ansung. (Probably the SR52, which is also reasonably priced.)
Any suggestions? Anything to avoid? I'd also consider used, but so far I have not found any used tillers, at least not anywhere near where I live, which is in eastern Pa.
   / Finally bought Kubota B3200HSD. Now I need a tiller. Suggestions? #2
As a new B3200 owner I thought our width at the rear tires was 53"?
I too am looking around for a tiller and also a box blade.
   / Finally bought Kubota B3200HSD. Now I need a tiller. Suggestions? #3
I think 23 is close enough for a 60", depending on what you expect of it. This is with a geared tractor with 1 mph at PTO speed in 1st gear. If your tractor has HST, then you should have no problem at all, as low minimum speed at PTO RPM is a big factor in sizing a tiller to your tractor.
For breaking sod it's going to be a bit much, but you can always make 2 or 3 passes, going deeper each time.
Covering the rear wheels is very good advice and I wished that I had bought a 6' for my 63" track width.
With 26.5 at the PTO, the only time I haven't had enough power was in solid, wet clay, which I really had no business tilling in the first place. I'm a big fan of our 60" KingKutter II, but we also have a 40" Phoenix/Sicma, that is also a well built machine and has the added benefit of allowing the 3 point hitch points to be offset, left or right.
2015 Caterpillar 305.5E2 CR (A57148)
2015 Caterpillar...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58216)
SKID STEER...
2003 Mack CX613 Vision Day Cab Truck, VIN # 1M2AE06Y43W014841 (A57453)
2003 Mack CX613...
2006 Dodge 3500 (A57148)
2006 Dodge 3500...
Cargo Van (A59230)
Cargo Van (A59230)
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
