Finally added a grapple
   / Finally added a grapple #1
Camper
O'Fallon, IL
Ford 1920
I've been wanting a front loader for a long time. Finally added a grapple to the toy mix and hoping to be done with loading brush on a trailer and then unloading the trailer at the brush pile.
   / Finally added a grapple #2
I don't think you will be sorry. If you have a lot of brush, logs or rocks to handle, it is hard to beat a grapple.
   / Finally added a grapple #3
Between bucket, forks, and grapple, the grapple gets the most use on my tractor. Agree with kOua, you won't be sorry. They are a good investment.
   / Finally added a grapple #4
It looks like you went with a Tomahawk - what do you think of the quality?
   / Finally added a grapple #5
I've been wanting a front loader for a long time. Finally added a grapple to the toy mix and hoping to be done with loading brush on a trailer and then unloading the trailer at the brush pile. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=467157"/>
That's a nice 1920, looks like you have calcium filled rear tires with a little leak from the valve stem. I have the same problem with my 1920. Gonna take them apart soon and clean them up. How is the quickie loader, my 7108 loader is vey weak with its curl function. Lifting it ok but curl is awe full. Did you add a third function or are you using remotes from the rear.
The tires do leak. I've thought about replacing them and have found the rears at reasonable prices on the web but the front wheels are very expensive. The quickie loader works pretty well. No complaints so far except for the curl speed. Seems to take forever when curling the grapple down to pick up something. Yes, using the remotes from the rear. Easy connect that way.
Seems to do the job for me. It's only a one cylinder so that's a drawback on uneven loads but it was half the price.
   / Finally added a grapple #8
It really would be a good idea to break down those rear wheels, and clean up the insides.
My 1920 rear wheels were already too far gone when I bought the tractor 2 years ago.
Had to buy 2 new 13" wheels, because original 14" wheels are no longer available ...anywhere.
Would suggest sandblasting, and then 2 coats of marine epoxy paint.
Then add new tubes filled with windshield washer fluid.
CaCl is Horribly corrosive stuff!
2013 Ford E-350 Cargo Van (A56858)
2013 Ford E-350...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
8065 (A55852)
8065 (A55852)
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
