Finally, a barn built with our new connectors
   / Finally, a barn built with our new connectors #1
wroughtn_harv
Super Member
Denison, Texas
2013 Volvo MC85C
It's been awhile in the making. And the inspiration for the whole thing started with two influences. One was a friend wanting me to come up with some new products his factory could manufacture. The other was all the interest shown here on TBN by members wanting a chance to build a metal building that would be strong, simple, and not require welding or equipment they needed to rent to do the job.
The patent application is in the mail. The attorney says I can now share it under "patent pending".
We're building a twenty four by forty shop with twelve foot walls, three-twelve pitch roof, and a sixteen foot overhang on each side. It'll have two twelve foot wide openings for roll up doors and one service entrance.
First we had to lay it out.
Then we had to drill holes and set posts.
After that is was time to form up the shop floor. This is a picture of the brick ledge kind of thing we do on metal buildings. We use a two by two (one and fiva eighths by one and five eighths) nailed to our forming lumber. This gives us a ledge for the sheet metal to go down bdside the slab and still have a floor so the varmints don't have easy acaess.
One of the things we did was put in the plumbing in the slab for a restroom if one is ever required down the road. It only takes a couple of minutes now but would be a major project later. We put in the P trap and ran the three inch PVC beyond the wall. We also put in a future water source access.
We mixed the concrete on site for the slab.
It took a lot of sand, gravel, and cement. We started mixing about two in the afternoon. It took sixty mixer loads. We had it all poured just before eight in the evening.
Now we'll measure up twelve feet from the slab and cut all the posts to height. The overhang posts will be cut about three feet four inches shorter than the barn posts.
When everyone arrives Saturday morning for the barn raising we'll have the posts cut to size and they'll have a coat of primer.
What makes this work and what I've applied for a patent on is this principle.
These come in rights, lefts, straight throughs. The idea is the brackets are placed on the posts and attached via self tapping screws. Then the four inch purlins are cut to fit between the posts and then attached to the brackets or connectors with self tapping screws.
Originally I came up with one piece that was a right, a left, and a straight through. But then as I saw confusion in the eyes of those I showed them to I realized maybe offering three pieces would be easier for folks to understand.
This is a shot of a corner using the original design.
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
