Final reduction gear oil leak NH 1925
   / Final reduction gear oil leak NH 1925 #1
jhland
Hi. My first post and need help. Came across this site and have bean reading for long time. NH 1925 MFWD front axle final reduction gear oil leak. My question is can i press the first bearing and gear together off or just the bearing alone. Then gear take off C clip or snap ring then press last bearing of shaft and hub. Don't know if bearing went bad and cause seal to leak. Will get one or two new bearing and seal. Thanks for the wealth of information onthis site...
   / Final reduction gear oil leak NH 1925 #2
I usually pull the bearing off first using a couple rolling head prybars. But there is no reason you can't pull the gear and have the bearing come with it. Don't freak out when you see the retaining ring in two pieces. It's supposed to be that way.
2007 TROXELL 130BBL VACUUM TRAILER (A53843)
2007 TROXELL...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A53843)
GRID SHAPED BUCKET...
1980 TIGER TA KILL TRAILER (A53843)
1980 TIGER TA KILL...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
