Final reduction gear oil leak NH 1925
   / Final reduction gear oil leak NH 1925 #1
jhland
Hi. My first post and need help. Came across this site and have bean reading for long time. NH 1925 MFWD front axle final reduction gear oil leak. My question is can i press the first bearing and gear together off or just the bearing alone. Then gear take off C clip or snap ring then press last bearing of shaft and hub. Don't know if bearing went bad and cause seal to leak. Will get one or two new bearing and seal. Thanks for the wealth of information onthis site...
   / Final reduction gear oil leak NH 1925 #2
I usually pull the bearing off first using a couple rolling head prybars. But there is no reason you can't pull the gear and have the bearing come with it. Don't freak out when you see the retaining ring in two pieces. It's supposed to be that way.
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
2012 INTERNATIONAL WORKSTAR 7500 HYDROVAC GUZZLER TRK (A53843)
2012 INTERNATIONAL...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
2016 SANY SY215C LC (A53843)
2016 SANY SY215C...
2012 KENWORTH T800 (A53843)
2012 KENWORTH T800...
