Fimco up on the 1850
   / Fimco up on the 1850 #11
Why are your tread patterns reversed on your outside tires? Just curious.
I think that I can answer this question. Because the rims are built with an offset, you have to think which side they are to be mounted on. The tire tread pattern should point forward no matter which side. Because of the offset, you can not take a tire off one side and switch it to the other side. You can mount it on the hub, but the tread will be reversed. The trick is to have a spare for each side, with the correct offset.
   / Fimco up on the 1850 #12
Dear Eddie,
Yes, you will track chemicals around. If you are going to spray going forward, you probably want to have the spray booms outboard of your tires. Herbicide will transfer, and you will have tire marks, aka dead grass, all over.
Like Woodlandfarms, I priced out the build your own, but I came out $50 above buying the package. So, I bought the package. We use it during weed season, and again to put out fire retardant. Yes, it sits idle most of the year, but it saves so many days of time during our noxious weed reduction season that it paid for itself in the first year.
I highly recommend plumbing in a recirculation loop, which enables good mixing, and the ability to spray wetable powders and high solids.
How much land? Depends on the spray rate, and the concentration of the herbicide. We do only spot spraying to remove invasive weeds, e.g. poison hemlock, poison oak, as an adjunct to other methods, such as mowing, pulling, and grazing.
All the best,
Peter
Interesting setup.
I'm still in the stalling, hoping for a great deal to show up in getting a sprayer catagory, so I don't know anything about them yet.
It looks like your driving over the chemicals after you spray them. Does this have any effect on the plants or your tires? It's not something that I think I'll do, but since I have some pallet forks and I'm leaning towards just about anything but a three point set up, you have me curious.
How much land can you do with 25 gallons? Do you have any comments on how the electric pump works? OK? No good?
Thanks
Eddie
And now for more fun
The Fimco boom does not bend in the opposite direction. That is, unless, you try and back out of a place you should not be and concentrate looking backwards and not forward and then you look forward and you see your boom that is supposed to not bend backwards bent backwards. Who put that stupid tree there anyway?
Also, there is a lot of chemicals left over at the bottom of the sprayer. Even though the Fimco cannot pull it out, there is at least a gallon or two left. Like an idiot I poured it on the ground when I should have poured it into my backpack sprayer and got some excercise and spot spraying done... Based on 200 per 2.5 gallons I would say I dumped $10 on the ground...
Lessons for the day I guess....
Just an update on Fimco quality. It has developed a pinhole leak in one of the on off valves. On closer inspection it appears that a plastic seam in the molding process is thin.
Will call them on Monday to get parts....
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2020 KENWORTH T680...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
