Sprayer Fimco sprayer pressure gauge
   / Fimco sprayer pressure gauge #1
buckthorn
Black Earth, WI
New Holland TC33D, John Deere x590, John Deere 325, Kubota RTV 900
I was testing my 55 gallon 3-point Fimco sprayer yesterday (with water) when I saw water pouring out of the pressure gauge. There are no clogs anywhere -- I checked. Fortunately I think I still have enough water pressure to spray an acre with glysophate this week.
The gauge seems to be busted, although I don't know how or why it got to be that way. Has anyone else had this happen? The sprayer is only 2-3 years old.
   / Fimco sprayer pressure gauge #2
Happens all the time. Plug hole, spray and get another gauge when you get a chance. Dry is OK, liquid filled is better. All you need is a 0-60psi reading.
   / Fimco sprayer pressure gauge #3
Glyphosate (RoundUp) is very corrosive. The OEM FIMCO gauges are rather cheaply manufactured. It doesn't take much to get one to leaking. I replaced mine with a glyserine filled T-JET gauge. I didn't like the tiny FIMCO gauge. Too hard to read while on the move.
Thanks, that makes me feel better. I suppose that it easily have been all of the Roundup. Stupid question: do you have any suggestions for plugging it up? A bolt, I suppose.
   / Fimco sprayer pressure gauge #5
That'll be a tapered pipe thread. Any good hardware store or plumbing supply shop should have pipe plugs. A bolt will ruin the threads.
Hmm, thanks. So when the FIMCO online catalog identifies the OEM gauge as 1/4 inch MIPT, that means I need a 1/4 inch tapered pipe thread? I think I just answered my own question. Doh.
   / Fimco sprayer pressure gauge #7
Good advice from FarmWithJunk--get a glycerine filled larger gauge and I'll add I like the 0-60 psi better because easier to see.
I picked up a plug at HomeDepot for about seventy cents. It worked perfectly! No leaks, and the spraying went smoothly -- I just had to gauge the pressure by eye.
I'll look into picking up a new gauge later -- I usually don't need to use more than ~30 psi, so the 60 sounds fine. 400 is overkill. I don't understand the difference between "dry" and "liquid", but whatever I get, I'll be sure to keep it clean this time.
Thanks for the advice everyone.
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
