Sprayer Fimco 3pt Sprayer
   / Fimco 3pt Sprayer #1
deereman10
Bronze Member
Elroy, WI
John Deere 2440
I'm looking at a Fimco 3 point 40 gallon sprayer. It's got a 10' boom. I've got about 15 acres that need to be killed off with Glyphosate this spring. Anyone have any experience with this brand? Comments? It's $440
   / Fimco 3pt Sprayer #2
i have one, but its the lg55. i believe it has a 55 gallon tank though and twin rear booms . the total boom spread on mine is just about 12 feet i have found while using it. i've had it for 4 years, and its worked flawlessly. only thing i found out is to remove the lower plastic filter bowl when storing in cold climate...cause they shatter. also on mine, i had a few flawed welds...not enough penetration on the steel. i was going to fix it myself, but decided to let the dealer do it under warranty. i noticed the separation when filled with water. now that was 4 years ago, and there is no problem with it since.
   / Fimco 3pt Sprayer #3
I have a Fimco with a 55 gallon tank and a 11+ ft boom I've been using on my 60 acre pastures for 6 years. It's a good sprayer. If you're going to use it for glysophate regularly, you'll need to get the special silver colored pump that's resisitant to the acidic glysophate.
   / Fimco 3pt Sprayer
There is also a 55 gallon fimco sprayer available however it doesnt come with a pump. Would the Hypro 6 roller PTO pump work for it?
   / Fimco 3pt Sprayer #5
Be sure and hose off the back of your tractor after each use. Also run oil through pump when storing. Boom arms are a little flimsy in my opinion.
Definately get the Silver(ie more expensive pump) pump if spraying round up.
Good set-up overall
-mike-
   / Fimco 3pt Sprayer
Do i really need the silver pump if I'm only going to run round up through it at the most 3 times?
   / Fimco 3pt Sprayer #7
i have the black colored pump on mine...use round up and hi-dep. have used it thru 4 seasons. has worked great. i use the neutralizer everytime i put it away. no leaks yet
   / Fimco 3pt Sprayer #8
I have the 60 gal model and am happy so far. Mine has the cheaper hypo pump and I just make sure it gets cleaned well. I use Nutra-Sol (I think thats the name) and then fill the pump with vegetable oil when storing. So far, so good.
   / Fimco 3pt Sprayer #9
Look at an Ag Spray 3 point hitch sprayer. Get the biggest tank your tractor will handle. Most of the spraying time is traming back and forth to refill. The one I bought does not have a boom but rather one nozzle on the back that sprays a path 20 ft. wide and does have a gun. That way you don't have to worry about tearing off a boom.
2020 Freightliner M2 106 S/A Dump Truck (A50323)
2020 Freightliner...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
Unused 2025 CFG XZ20R Mini Excavator (A50322)
Unused 2025 CFG...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2009 MIE Conter Console Police Patrol Boat with T/A Boat Trailer (A50324)
2009 MIE Conter...
