Fimco 25 gal sprayer
/ Fimco 25 gal sprayer #1
crazyhorsemd
cincinnati, Ohio
2000 New Holland TN70, 1974 White 1370
hello all,
Got 25 gal Fimco sprayer, fit on ATV for spraying around farm. Anyway, has worked well till this year. Pump kicks on builds pressure but doesn't turn/cycle off when pressure is built. Pump just keep running. any thoughts?
crazyhorsemd
/ Fimco 25 gal sprayer #2
Maybe a slight plug in the business end of the wand. Try removing the nozzle and strainers to see if it behaves better.
/ Fimco 25 gal sprayer #4
I have to clean the debris out of my pump every so often, it's easy to do. Prolly need to put a screen on the intake one of these days.
/ Fimco 25 gal sprayer #5
If it's a by-pass pump and it's won't cycle after attaining it's desired pressure
it's got a pin hole leak in the diaphram.
I've rebuilt a few in my time but truth be told:
It's just as cheap to toss it and buy another.
My 2 cents
/ Fimco 25 gal sprayer #6
Didn't think these pumps cycled either.
/ Fimco 25 gal sprayer #7
Mine will do the same if there is air in the lines. I power it up and then open both the sprayer valve and the gun till I get fluid. From then on it cycles just fine.
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
Frontier 4' 3Pt Mower (A66408)
Frontier 4' 3Pt...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
