FILTERS
   / FILTERS #1
CHUCKWAGON
TENNESSEE
FARM PRO 30 HP 4X4
DOES ANYONE HAVE THE AMERICAN X- NUMBERS ON CHINESE FILTERS OIL & FUEL ? I HAVE A 30 HP FARM PRO 4X4 AND IT'S READY FOR IT'S FIRST SERVICE. I CAN'T FIND ANY X-REFERANCE NUMBERS ANY WHERE. grrrrr
STAMPED ON THE OIL FILTER IS (JX85100A) AND THE FUEL FILTER IS (HECX70100) THANKS /forums/images/graemlins/confused.gif
   / FILTERS #2
Chuckwagon- I won't be any real help - I have the Y385 which is different from yours. But since you haven't had any replys yet, I'll suggest something you might try. Measure your filters, outside diameter, length, and the gasket OD, & ID, even though it's built on the filter. The critical measurement is the pipe nipple that the filter threads on to. You need to know the diameter and the number of threads per mm. A machinest would have a guage to measure, or maybe a topnotch automotive store might measure the threads for you. With this info you can go online to your choice of filter companies (we used WIX), and they told me on mine that it's an 85626 oil filter that actually fits a Jeep engine. The fuel filter was something off a Ford product. The air filter was an industrial universal. But that was for mine, but they did come up with good numbers. Good luck, and sorry I couldn't be of more help. Maybe someone else will have an easier way. Yugo
   / FILTERS #3
Pretty sure that's a Y395T or a TY395 engine and going by an old link found here a Motorcraft FL-1A oil filter and a Napa 3195 fuel filter will fit your engine. If interested you can do a search in this forum for "filter number" and the link will be listed in one of the posts.
Hope your enjoying your machine! I used my to remove another stump this weekend.
   / FILTERS
I DID JUST THAT, WENT TO NAPA AND TRYED TO MATCH A FILTER. THE NAPA (FL-1) WAS SOOO CLOSE EXCEPT FOR THE TREAD, I NEED METRIC GRRRR. BACK TO THE DRAWING BOARD AGAIN. /forums/images/graemlins/mad.gif
   / FILTERS #5
Chuckwagon - You're half way home. I can see the light at the end of the tunnel, and it's not the train! If you were happy with the can and gasket size of the Ford filter, even though the wrong thread size, I've done a little research, and a very common thread size is 20 mm by 1.5 thread for oil filters. There are other combinations. My suggestion at this point is use the Wix on-line technical help (not listed on front web page but you'll find it if you look a little farther on that site. If you would run those filter numbers by them, (they are experts at it), and give them the make and model of the engine, they should be able to find what you want. Be sure to tell them that the Ford filter is similar in size, but just threaded wrong. Second choice is go back to your automotive dealer, and ask them to let you look at their oilfilter book (Oil filter Bible). The last 50 pages is filter numbers, and all the dimensions. The easiest way to find what you're looking for is probably look for 20mm X 1.5 in the thread size of their chart. Then to the left of the thread size will be the can and gasket dimensions. You definitely want a anti-drain back and 7-13-lb relief pressure valve. Make sure it's an oil filter - NOT hydraulic filter. The 20mm thread is approximately 0.030+ over 3/4 " - not quite 25/32's. And remember the pipe nipple, if it is 20 mm, that's the OD, and the filter hole will be the inside thread (approx. 1/16" smaller). I'll let you in on one top secret. When you find your filter, be sure to fill the filter full of oil if it's and upright, and 2/3 full if it's on its side, and put the oil in the engine first, and the filter on last. This will help purge the air out of the system. Seriously. Top secret .Shhhh! If I could help anymore, let me know. Yugo
   / FILTERS #6
Chuckwagon,
My original engine oil filter was JX85100C - not sure of the difference between the "A" and "C" - but a Fram P1653A is a perfect fit. Can't help with the fuel filter. Mine is CX7085 and I can't find a X-reference for it.
   / FILTERS #7
Went to pick up some filters today and found out that the filter I have been using for the engine, Fram P1653A that I gave earlier, is actually a hydraulic filter. I was told it should not hurt anything (??), but, I really want to find the right filter for the engine.
There has to be a difference somewhere if the manufacturers make a similar filter; one for engine and one for hydraulics.
Sorry for the bad information, I am now searching again as well......
You would think the fram web site would a way to convert a hydraulic filter to an exact engine filter. /forums/images/graemlins/confused.gif
2018 Genie GTH-636 (A50123)
2018 Genie GTH-636...
2010 Autocar Xpeditor T/A Labrie Side Loader Garbage Truck (A51692)
2010 Autocar...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2006 Ocmis 125 R4/2 (A50123)
2006 Ocmis 125...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
