Filter Screen
/ Filter Screen #1
trk
I have a JD 950 tractor with a after market bucket. A while back the bucket stated to move very slow. There is no paper filter for the hydraulics on this trator, only a fine screen at the sump. The screen was dirty. I changed the oil and cleaned the screen. The bucket worked fine for only a short time. Again the screen was dirty. I figured the oil change only changed a portion of the oil, so I changed the oil again and cleaned the screen. The bucket worked good for only a short time. I am sure the screen is dirty again. Where is this "fuzz" coming from that clogging the scrren?
/ Filter Screen #2
Welcome to TBN:D
Does the seem like it's clogged with a rubber or steel material(use a magnet to check)? Steel may indicate the pump going bad, and rubber may mean a hose is deteriorating from the inside out.
/ Filter Screen #3
I would install a spin on type filter block assembly on the return side of the hydraulics. Also, this time, clean the bottom of the tank. This is where all this garbage settles.
/ Filter Screen
The material on the screen is not metal. It looks simulat to cotton "fuzz". I wouldn't think it is coming from a cylinder or pump. Can a hose that is bad cast off a material like this?
/ Filter Screen #5
Most hoses have a nitrile inner liner which is black. I know the fuzz you describe. I've never given it much thought. You don't park your tractor near your dryer vent from your house, do you? ;)
/ Filter Screen #6
I've seen lint in hydraulic systems that were wiped out with plain cotton rags instead of lint free wipes. Plugs up the filters quite badly. Of course this was on a system where a guy could crawl inside the tank to clean it out. I wouldn't have thought you could get enough lint in a small system to plug the screen more than once.
I would say cleaning the tank the very best you can with something that won't add lint is the best you can do. Or else add a filter and/or keep cleaning the screen until it quits plugging.
/ Filter Screen
The tractor is parked outside under a covered shed and not used much at all.
/ Filter Screen
If this is algae, what do I need to do? I have changed the hydraulic oil twice.
Massey Ferguson Model 66 Hay Rake (A65640)
Massey Ferguson...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
CASE 105C (A62177)
CASE 105C (A62177)
