Oil & Fuel Filter front end low-vis hyGard
   / Filter front end low-vis hyGard
The next oil change will not repeat this . It's a first change
only , so don't be concerned .
That is by BIG concern. The pic that I posted WAS the second oil change. The first change was @ 137 hours and that oil was BLACK and absolutely had metal in it. I drained it @ 210 hours and it had no metal in it but as you can see in the pic, it certainly is BLACK.
   / Filter front end low-vis hyGard #12
Just a question here. Does Deere offer the option of using a low vis, 75w-90 synthetic gear lube in the front axle? Not either/or on this series? Curious.
   / Filter front end low-vis hyGard #13
...... first change was @ 137 hours( metal in it) 2nd @ 210 hours ( no metal in it) but BLACK ....
250 hours and still giving black oil in a front mech drive.
I would have honestly said the case-hardening was gone
, but with no metal whatsoever , it's peculiar indeed.
My LR3 front diff was replaced last week due to case-hardening
failure , but the black oil was full of metal too . On a tractor there
is too much noise to hear the diff.
2018 Dorsey 55-Ton Trailer Low Boy, VIN: 5JYLB5537JPD006956 (DETAILED DESCRIPTION & PICTURES COMING (A59076)
2018 Dorsey 55-Ton...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
LOT: Cutters, Shears, Giant Chalk Line, 100' Tape Measure (A59076)
LOT: Cutters...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
