Filter Cross Reference #s For L3130
/ Filter Cross Reference #s For L3130 #1
Bucky4
Eastern suburbs of Pittsburgh
'03 L3130, '06 BX24, '11 RTV1100
Can anyone tell me or direct me to a site to get filter cross reference numbers for an L3130? At this time, I need to change the oil filter, but hydraulic and fuel filters are not too far behind so those would be appreciated too.
The Kub p/n for the oil filter is 70000-74035.
Thanks,
Jim
Vernon,
Thanks for the reply. I sure hope someone can help us. It's a very long haul for me to get to the dealer and the gas prices aren't making it any easier!!
Jim
/ Filter Cross Reference #s For L3130 #4
Get it shipped to you direct from the dealer. UPS delivers almost everywhere and they are not too expensive. It probably cost the same to ship several. I'm sure it would be cheaper than driving there. Just a thought.
/ Filter Cross Reference #s For L3130 #5
You might be able to cross the oil filter, but the hyrostat filter is special. You don't want to go cheap on it as the oil is under 2-300 psi when it is filtered.
jb
/ Filter Cross Reference #s For L3130 #6
I have tried the Wix site, and had no luck with a cross reference on any of the oil or hydro filters. You could order from tractorsmart. They are somewhat cheaper than my dealer.
www.tractorsmart.com
Maybe someone else has found a cross reference on the filters. Hope this helps.
Curt
/ Filter Cross Reference #s For L3130 #7
NAPA has the filters. You can find the cross references at their web site: http://www.napafilters.com/filterlookup/
Choose "Off-Highway Equipment" for the "Select a Vehicle" then choose "Kubota", tractors, and appropriate model or engine #. R/David
/ Filter Cross Reference #s For L3130 #8
</font><font color="blue" class="small">( NAPA has the filters. You can find the cross references at their web site: http://www.napafilters.com/filterlookup/
Choose "Off-Highway Equipment" for the "Select a Vehicle" then choose "Kubota", tractors, and appropriate model or engine #. R/David )</font>
David, have you purchased the NAPA filters? how do they compare to OEM? Price difference?
Bob
PS nice link
/ Filter Cross Reference #s For L3130 #9
I just purchased my l3130/BH90 -- so haven't used the NAPA filters yet. I have used their filters in other applications - they're high quality so wouldn't hesitate for the 3130. I don't believe NAPA has a x-REF for the HST filter (TA240-59900). Will need to get that through Kubota - $56.00+ online.
/ Filter Cross Reference #s For L3130 #10
</font><font color="blue" class="small">( I just purchased my l3130/BH90 -- so haven't used the NAPA filters yet. I have used their filters in other applications - they're high quality so wouldn't hesitate for the 3130. I don't believe NAPA has a x-REF for the HST filter (TA240-59900). Will need to get that through Kubota - $56.00+ online. )</font>
How much money have you saved going with NAPA vs OEM???
Bob
/ Filter Cross Reference #s For L3130 #11
I couldn't tell you. For me it's a matter of convenience. I usually order my filters, etc. in advance online (OEM). However if I need something immediately, I'll purchase locally through NAPA as it's a 170 mile round trip to my closest Kubota dealer.
/ Filter Cross Reference #s For L3130 #12
I am glad to get this information. I did a search about a year ago and did not find any WIX or NAPA filters then. Did I mess up or are these newly available or certified?
Vernon
/ Filter Cross Reference #s For L3130 #13
The web-site x-ref may be new, however the availiity within NAPA isn't. I know people who have been using them for Kubota and other tractors for several years.
Update:
I called around to a few local auto parts stores and, as expected, most could not x-ref the Kub oil filter; however, one did. (Did not call NAPA. Will try them to see if they have one. Thanks for the site info.)
Carquest was able to sell me a Wix filter and I used it last night. Physically, it's an exact copy of the OEM and since I've had good service from Wix filters, I expect it to perform very well too.
Cost was about $8, which is very close to the price of the OEM, but is definitely a savings for me since the Kub dealer is out of the way.
L3130 oil filter = Kub 70000-74035 = WIX 85311
Thanks to all that responded.
Anyone x-ref a tranny/hydraulic or fuel filter from either Wix or NAPA?
Jim
/ Filter Cross Reference #s For L3130 #15
All the filters for the L3130 (as are most other Kubota products), including air filters, fuel and hydraulic filters are x-ref'd on the NAPA site with the exception of the HST filter. Also, FYI - I checked on the box of the NAPA Gold Oil Filter (#1311) -- it states that it exceeds OEM specifications and does not void Manufacturer Warranty. I would imagine WIX, or any other quality filter would warrant the same. I really don't think there's great variance in price than with OEM. Especially if you order OEM online. R/David
/ Filter Cross Reference #s For L3130 #17
Wix manufactures Napa filters as well as others. The Wix- Napa numbers are identical except for the first digit on Wix. For example on a common automotive oil filter the Wix number would 51372 and the Napa number would be 1372. Wix air filters begin with 4, fuel with a 3 and oil with a 5. We use a ton of Wix where I work and I use them on our Kubota's. Sometimes if it is a new filter you are stuck using oem for awhile. Right now we have a JD that is that way. Good Luck, Brian
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
JLG HC3 8ft Boom Lift Man Basket Attachment (A61572)
JLG HC3 8ft Boom...
6' ROTARY MOWER (A64280)
6' ROTARY MOWER...
ATLAS TC-229 ELECTRIC/AIR TIRE CHANGER (A64281)
ATLAS TC-229...
