Filling your gearbox with grease
   / Filling your gearbox with grease #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
This came up in another thread and I was curious how many people do this with modern equipment. RC, FM, etc. Mine still has 90w but I haven't touched it in years. No leaks no problems. I should probably check it this weekend.
Rob
   / Filling your gearbox with grease #2
I messed with the old Gravely 2 wheel tractors and it said to use 140w gear lube and you cannot find it any longer. I drained everything and filled with grease and used them for years . Lubrimatic makes gear lube for boat motors and bearing grease I believe still sells / makes 140w gear oil in qts but it is very hard to find a store that sells it.
Bill
   / Filling your gearbox with grease #3
Rob
i had an older rototiller that had a leaky two piece pressed metal drivecase, with an enclosed chain between the tiller shaft and the drive pulley shaft. I installed a zerk in the upper area of the case, and pumped the cavity full of about 4 tubes of cheap grease. It ran for years after that, with no problem.
I don't think I would use grease on a normal gearbox. I usually drain the old petrol based gearbox oil, and then fill with Mobile 1 90W. But I wouldn't put the expensive stuff into one that leaks.
   / Filling your gearbox with grease #4
We use a 50-50 mix of non-detergent engine oil and #2 lithium grease for old gearboxes-been doing it for years and haven't had a failure yet.
   / Filling your gearbox with grease #5
You can use a flowable grease such as a #00. It has the consistency of a slime. My Rhino 10' cutter has it in all 3 gear boxes.
   / Filling your gearbox with grease #6
Make sure you use EP-00. The EP designation matters.
   / Filling your gearbox with grease #7
I run grease in my old 6' brush cutter. Works fine for the last 3 years. Then again, the machine came free with the farm... I wouldn't do that with anything that I actually had money invested in.
   / Filling your gearbox with grease #8
John deere "corn head grease" works very well .
rick
   / Filling your gearbox with grease #9
When I messed with the Grey Market tractors, some of the importers put Lucas additive ,full stength, in the front ends to replace 90 wt. It would make a grease slick around the joint but would stay in pretty good. I have a friend that has a mower that the gear box gets so hot you didn't want to touch it. It finally blew the seal out. He got a vent for the top and filled it with Lucas. It has done great since.
   / Filling your gearbox with grease #10
Kays Supply said:
When I messed with the Grey Market tractors, some of the importers put Lucas additive, full strength, in the front ends to replace 90 wt. It would make a grease slick around the joint but would stay in pretty good. I have a friend that has a mower that the gear box gets so hot you didn't want to touch it. It finally blew the seal out. He got a vent for the top and filled it with Lucas. It has done great since.
A plugged vent will cause a gearbox to heat up and cause oil to be pushed by a seal.
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
