Filling up modern cars from a fuel can.
   / Filling up modern cars from a fuel can. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
So I keep 5 gallons of gas on hand for my generator. I store the generator dry and only splash a little fuel in it once in a while just to run it now and then. I had been giving the 5 gallons of fuel to my son every few months just to get fresh fuel. The problem now is he got a new car and his car, my wifes car, and my truck have the no gas cap fuel filler. Is there an easy way to get gas in these things from a fuel can? My truck came with a little spout that's attached to the jack for this but it looks like a pain.
   / Filling up modern cars from a fuel can. #2
I’ve never seen one of these to see how they work but I think my VP gas cans with a spout would work.
I don't think it would, I'm not sure what it takes to open the fuel door.
   / Filling up modern cars from a fuel can. #4
Check owners manual, my car has funnel with tire tools
   / Filling up modern cars from a fuel can. #5
Like I’ve said I’ve never seen one, but the VP cans have a plastic tip that’s nearly the same size as a real gas nozzle. I’m guessing there’s no black magic involved and it just takes a round piece that’s the right diameter.
   / Filling up modern cars from a fuel can. #6
My neighbor's car has that, too. A little funnel to use in an emergency if you should run out of gas. He said it took him a while on-line to figure out where it was. Go to a u-pick junk yard and get a spare for a couple bucks. ;)
   / Filling up modern cars from a fuel can. #7
The little funnel/spout works by depressing the release buttons inside your vehicle's fuel neck. When you shove it in the neck, the funnel passes and depresses those release buttons which then allows the locked "door" to open and the funnel is inserted. Most fuel cans don't have that perfect spout size so you can't get the buttons depressed and the little door locks you out.
   / Filling up modern cars from a fuel can. #8
You have to use either the little funnel that your car came with or an aftermarket one available and most any retail outlet that sells automotive supplies.
   / Filling up modern cars from a fuel can. #9
You should go with a BIG funnel.
   / Filling up modern cars from a fuel can. #10
If you can get a funnel in then a Pocket Pump should work. I think the model without the mechanical nozzle might be the better one. Good for all your small refueling needs and one of my better /worthwhile purchases for $30 Canadian.
Check it out here: Pocket Pump Ltd. - Heavy Duty All Purpose Pump
Al
ROADTEC RP-190E-3043 ASPHALT PAVER (A51246)
ROADTEC...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2022 Freightliner M2 106 Medium Duty Rollback Truck, VIN # 1FVACXFC5NHNM7347 (A51572)
2022 Freightliner...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
