Ballast Filling Tires
   / Filling Tires #11
fyrewil said:
OK...
I have read about filling tire's to get extra traction... But what do you fill them with? Water? How do you (I) go about doing it and with what?
Willie
:confused: :cool: :rolleyes:
I used, recycled anti-freeze. You might want to check around, as I found a repair shop near my house that would fill tractor tires with used anti-freeze, and that did the trick on my 4100. With the 4310, I am gonna try the ballast box first as these tires are a bit heavy already, let alone adding in fluid-based weight. switching tires is tough enough now, without the addition of fluid to them. As Roy has indicated filled tires do improve stability, primarily. With a Ballast box, you can get more tread on the ground due to the increased weight.
   / Filling Tires #12
Also I have heard of some people on this forum that use foam, but I don't know how effective that is. But no leak worries.
Foam Fill
apparently it can be acquired with varying levels of density - making it heavier and heavier.
or you might want to look at this product
TRAK N SEAL Executive Overview
says it is heavier than foam or CACI
30pc 3ft. x 8ft. Red Polycarbonate panels (A53424)
30pc 3ft. x 8ft...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A55314)
2022 John Deere...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2014 COMPTANK ACID TRANSPORT TRAILER (A55745)
2014 COMPTANK ACID...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
