Filling tires on my T574
   / Filling tires on my T574 #1
Torvy
Super Member
North East Texas
TYM T574H
I think I have what I need to fill my rears with water. Not worried about freezing. On the rare chance we get temps that low, I can put it in the shop.
My biggest concern is losing the bead. I don't have the patience or strength to deal with that.
Any suggestions about how to do this without having my R4s pop the bead?
   / Filling tires on my T574 #3
I have mine filled with water but it has tubes. Not sure I would want the water in direct contact with the rim. I suggest you get some tubes for it.
   / Filling tires on my T574 #4
When I was living in Arizona the rental repair mechanic put a radiator anti- corrosion/anti-rust inhibitor in the front end loader tires before adding the water. Might be something to consider? If not going with tubes.
   / Filling tires on my T574 #5
   / Filling tires on my T574 #6
Always got to consider corrosion.
   / Filling tires on my T574 #8
If I could find a smaller quantity of this stuff...
This is what the dealer installed in my rear tires. Their literature says it’s non corrosive to rims and keeps the tire rubber soft. It does also protect from freezing.
   / Filling tires on my T574 #9
I have never broken a tire bead on any of my three tractors when tire pressures were maintained at tire manufacture's suggested pressures.
I have air in all tractor tires.
   / Filling tires on my T574 #10
My tire journey.
