Ballast filling rear tires ?
   / filling rear tires ? #11
<font color="blue"> ".....will I loose fuel millage or will there be not much loss. I have AG Tires..." </font>
Holzster- You won't use anymore fuel and loaded tires will also improve the ride, less bounce. If it were me, I'd load up those R-1's on that 4330, only exception would be if flats would be a potential problem. Have fun /forums/images/graemlins/laugh.gif
   / filling rear tires ? #13
I've been struggling with the same question. Should I or Shouldn't I? I have a 3710 with R4s and have come up off the ground in the rear more that once! Only problem is I wonder how bad the ruts are when you use it to mow grass in the Spring?
   / filling rear tires ? #14
I don't have my owners manual in front of me but I think the valve stem is to be at the 10:00 or 2:00 o'clock position and fill till it comes out.. then fill with air.
Bass as long as it ain't too soft then you won't have any problems with ruts, all you can do is try it.
notamustang,
thanks for the chart,very informative.
vulcan101
2020 MACK P164T (A58214)
2020 MACK P164T...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
LOT: (2) 2-Wheel Dollies, Roller Stand, (3) Screw Levelers (A59076)
LOT: (2) 2-Wheel...
1985 Allmand Max Lite III LD30-3CE S/A Towable Light Tower (A55973)
1985 Allmand Max...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
2019 Freightliner Derrick Digger Truck (A55973)
2019 Freightliner...
