Tires Filling rear tires
   / Filling rear tires #31
Tires can and do get damaged and leak. Nobody seems to mention that possibility to much. I'm not sure I would want however many gallons of calcium chloride or some other corrosive leaking into my yard and soil or wherever the thing might be parked. I know there would be a big argument at my house over it since my wife is a garden professional. The Kubota dealer in my area just uses Rimguard now for that possibility and the possibility of rim corrosion.
Not to mention the CaCl salt water squirting all over your inner fenders as the tire rotates when your tire springs a leak until it goes flat. I fought rust issues for a while. The CaCL was in an innertube as it should be, but that does not solve the dumping salt water everywhere problem..If you want to use CaCl, then by all means please do, I know a lot of people still do. It is just not for me.
James K0UA
   / Filling rear tires #32
pulled the trigger today on filling my tires. 110 gals of product to fill my 17.5-24 tires
I pick it up, install myself
Rv antifreeze 55 gal drum $209 each 418 plus tax
Washer fluid 110 gal 1.67 per gal 183.1plus tax
take tractor or farm call
Rimguard 110 gals 3.00 per gal $330 opted for $79 dollar service charge instead of trailering tractor 80 miles total no tax farm use $409.00
I chose Rimquard to install in my driveway on friday
   / Filling rear tires #33
Larry11 said:
I'm thinking of filling my rear tires on my Kubota B3030 with Rim Guard. Has anyone used this product and how does it workout?
I have a B3030 with Rim Guard in the rear tires. It made an amazing difference in traction, and stability with the loader. I seldom use 4wd with a land plane anymore.
   / Filling rear tires #34
art said:
You must have requested the dealer to add the tubes as tractor tires have been coming without tubes for about twenty years now. We have added them for different customers when adding fluid upon their request. When the tires are sealed properly it doesn't make to much difference liquid is in them as once the oxygen is gone the rims won't rust. We have seen them go over fifty years without needing to be replaced.
Once again I will state if you don't need it, the whole machine will work longer and cost you less! We are filling less then 40% of the tractors we sell. Those that are still filling them are old school farmers that don't like new technolgy or just to change and often quote "thats the way dad did it and it's got to be good enough for me". Good thing they did away with the crank before dad passed away!
Modern tractors are designed to run comfortably with liquid tire ballast, old school or not. What I have noticed is that dealers that don't 'believe' in liquid tire ballast are either not equipped to install it, or don't make enough off of it. There is no doubt that for most tractor tasks, some form of liquid ballast is beneficial. The debate rages as to which product is better, for my money it is rimguard. Most of your comment is a bit condescending...
   / Filling rear tires #35
I am glad I put Rimguard in mine and I am sorry I didn't do it sooner after having a lot of rear wheel liftings in off camber situations. I feel a lot safer with it in the rear and I know it's non corrosive which is a plus......
   / Filling rear tires #36
A little off topic....So is filling the tires harder on the tractor axle/bearings and stuff?
   / Filling rear tires #37
Wondering how you could possibly notice that a dealer was not making enough off of it...
:confused:
   / Filling rear tires #38
I got rimguard in mine and love it. never looked back since.
   / Filling rear tires #39
Calcium chloride is a corrosive fluid and should be installed in tubes rather than straight into tires. "Calcium chloride can corrode tubeless rims if the rim is not completely covered with solution (about 90 percent fill) when the tractor is parked," says Randy Taylor, Extension Agricultural Engineer at Kansas State University. Calcium chloride accidentally sprayed on sheet metal can cause it to corrode. Punctures or sloppy filling will release calcium chloride onto the soil. The mixture is a salt brine toxic to crops and other foliage.
This is an article that I found on Calcium chloride filled tires. Notice tire must be 90% full tubeless tire, but most will say go no more then 75% for mecahincal and handling reasons. I quess it's a personal choice, but for me, with all the toxins already being thrown onto our planet, why make or take a chance of making things worse? There are better options that are close enough in price.
   / Filling rear tires #40
I dont see how, as most of the weight would be carried by the tire into the ground, not by the axle. Maybe just a very little that is above the axle line ? Is that the way you see it?
James K0UA
Woods F21D Zero Turn Mower (A50514)
Woods F21D Zero...
Danhauser 3 pt Post Hole Digger (A50515)
Danhauser 3 pt...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
NORTHERN 3P-100 AG MIST SPRAYER (A51243)
NORTHERN 3P-100 AG...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
