Filling a Hundred Holes (6-feet across, 4-feet deep)
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #11
I assume the holes taper and aren’t cylinder shaped so I calculated the volume at half depth. That’s about 2 yards per hole so not as much dirt as I originally thought. I’d say 4 full scoops on your tractor FEL would about fill one. Although that’s packed yards vs loose yards so maybe 5 or 6 scoops.
Yeah, just waiting on the jurisdictional determination from the US Army Corps of Engineers. The wetlands should not fall under their jurisdiction, so pond-building is high on the to-do list. It might take a month or so, since it's 4 acres of wetlands. In the meantime, I would like to fill these holes and also build an embankment slide for the kids.
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #13
Be aware of the quality of the dirt from low areas. It may be silt or muck. It may not be good fill material. Nasty stuff when wet.
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #14
Might check around and hire a good grader operator. They can move a lot of dirt short distances and do so fast. Leaves a level surface. Also can do ditching, and build many types of embankments.
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #15
It can be done with a smaller machine if you have a few years ;). If you dont want to wait big iron can make quick work of it.
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #16
You can buy dirt cheap by the semi load. Maybe $350 a load? Get a load dumped right by your holes and it will be easy to move the loose dirt into the holes with your loader.
With my skid steer I bet I could fill and smooth a hole in under five minutes if wasn’t having to move the material too far.
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #17
I can buy it for $100 but that’s a very area dependent price.
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #18
That is super cheap if you are talking semi and not tandem and cheap even for a tandem. Around here you are going to pay $100 minimum just for the trucking plus the cost of whatever you want hauled. Granted dirt is cheap but the people digging it up and loading it want something for their efforts.
Regardless I think OP is far better off trucking in material than trying to dig it up to fill these holes unless he already had a backhoe or excavator and a means to haul the dirt.
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #19
Craigslist ad here a few months ago offered free dirt, delivered, but you had to take at least 100+ loads.
Bruce
   / Filling a Hundred Holes (6-feet across, 4-feet deep) #20
You can try putting your name out to a few "dirt" contractors in your area. There are always some around my area who a looking for places to dump waste dirt from another project. My neighbor did exactly that and received 10 tandem dump truck loads of clean topsoil withing a week from a housing project totally free. He was very specific that he only wanted top-soil! Free sure beats paying for it.
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
16ft Heavy Duty Aluminum Ramps (A53472)
16ft Heavy Duty...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
