John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,048
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
My TC 33D goes in Tuesday to get the FEL put on (finally!) I had intended to fill the tires with Calcium Chloride. That seems pretty common in this area (Vermont). After reading some of the horror stories here about rusted out rims, I'm having second thoughts. The salesman (not the service guy) said they don't use tubes when they fill. He said rusting is not a problem, since they fill the tire to just above the rim (no air= no rust).
I'd appreciate any thoughts on this. Should I insist on tubes being installed? Or does this make matters worse (tube springs a slow leak, I little gets outside the tube and onto the rim ... with the little bit of air, it starts rusting)?
I don't envision the need to ever remove the weight (not concerned about turf damage). I'm running R4 tires on my TC33D. Mostly used for brush hogging, FEL work and eventually some landscaping/road work probably with a box scraper.
