Filled tires at lower levels
   / Filled tires at lower levels #31
It is not obvious to me that the axles are at the CG of your tractor. I think 75% fill puts all of the liquid below the CG.
Think about wheel spacers to widen the stance of the tractor. This provides tip-over resistance without adding very much weight. If you want weight for traction this doesn't help much, but you seem to be more interested in stability.
Not quite. Usually the COG is above and in front of the rear axles but varies of course with ballest placement and loader position. Here is the best referance I've found.
http://www.nstmop.psu.edu/tasksheets/4.12 Tractor Stability.pdf
I also like spacers and 75% rimguard fill. They work great.
BUSH HOG 14' ROTARY MOWER (A52708)
BUSH HOG 14'...
2005 Ford Crown Victoria Sedan (A56859)
2005 Ford Crown...
78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
78in Dual Cylinder...
2016 KOMATSU D65PX-18 BULL DOZER (A58216)
2016 KOMATSU...
8ft Disc Mower (A57454)
8ft Disc Mower...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
