ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,724
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Yeah, we've drifted a bit. But it's still good discussion with educating points being made.
Not sure which of your tractors you are talking about concerning filled tires and mowing?? I mow with a JD2210. I filled the rears for stability while mowing road banks. I'm sure it's harder on the turf since I've added weight. But the stability gain was worth it in my case. I consider tire fluid to be the most effective weight. It's location and the fact that it does not load the chassis is the reason. Wheel weights come in second in my opinion. Only reason they are rated 2nd is because it takes so many to equal the weight of fluid and they are very expensive per pound.
